Home > General & Technical (L663) > Driven: New Defender - On & Off Road. Is it a Pretender?
Page 10 of 10 <12345678910
Tim in Scotland
You mean you don’t drive your own car like that?
neither do I  Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #860616 9th Oct 2020 11:21am
lohr500
Pity the poor sod who buys it as a low mileage demonstrator!!!
Post #860618 9th Oct 2020 11:30am
pbhawkin
Australia
What’s going on with the fog lights that appear to be alternating in being on and then off when he was driving through the muddy track? Does it have adaptive Corning lighting?
Post #860738 9th Oct 2020 10:16pm
Tim in Scotland
Yes, All models with fog lights have Adaptive Cornering lights. It’s the same on most modern Land Rovers with adaptive type headlights and fog llights, in older cars it was a separate lamp in the headlight cluster but here they utilise the fog lamps instead. Very useful to see the kerb or verge on country roads at night or in dark multistorey car parks. You don’t know you have them until you see another one using them! They are also visible on the video I posted about doing the Adventure trek day at Dunkeld LRE last Saturday
This video around 9 minutes 20 seconds in you see it and again at 10m 30s in my car and the silver one are both doing that.
Post #860747 9th Oct 2020 11:28pm
Naks
Naks wrote:
One more thing that owners may want to experiment with and report back:
After experimenting more with the hill hold during the outing, we have found that in Comfort mode, the Hill Hold automatically brakes & holds the vehicle if we stop on a hill, *without having to touch the brakes*.
However, when in any of the TR modes, it does NOT automatically hold the vehicle on a slope - you have to press the brake pedal and then press it again and then only will it hold the vehicle.
Some more feedback on this: we went back to the same trail today, with another new 110.
We tried the Auto Hill Hold in both, and it works 100% in the new car, but not in my mate's.
We also discovered that when my mate's rolls back, the engine stalls, which is very dangerous on a trail.
So definitely an issue with his vehicle, which hopefully a software update will fix. --
Post #860991 11th Oct 2020 4:00pm
Tim in Scotland
Off road I have found also that you get way less wheelspin using Sport mode in low box and the diesels will pull away in manual 3rd, 4th 5th and 6th no problem at all with no fuss from wheelspin. I notice on TFL’s video when they drove the P400 from Denver LR and in their most recent video both cars suffered severe wheelspin on the rock crawl and when you look at the dash it shows they are in D so trying to pull away in 1st. In the diesel max torque is 430NM from 1400 rpm and I was rock climbing in 3rd and 4th at 1600/1700 revs doing 5 mph and less. The ECU will also automatically downshifts as the revs drop without having to manually do the shift. One thing if you stop it will also automatically engage 1st so you have to remember to manually shift to 3rd or 4th before pulling away again. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #861007 11th Oct 2020 6:19pm
Re: Driven: New Defender - On & Off Road. Is it a Preten
Chicken Drumstick wrote:
Sadly though, there is some bad news. Well not bad, more catastrophic. Under some conditions the gearbox is the most dreadful, awful gearbox I’ve ever driven. Once rolling it went well enough and complimented the engine. The gear shifts were also smooth. The problem is twofold. It seems to be completely dimwitted at times and leaves you quite literally sitting in the road not moving.
There are two flavours of this. The first is from standstill, if you pull away normally, sometimes it would do nothing, I’m not entirely sure if this was the gearbox or the throttle. But the engine doesn’t rev and you don’t really move. Then it will suddenly lurch forward with little to no warning. This makes some kinds of normal road use quite horrid. Also despite being an automatic, it seemed to have an unwillingness to want to crawl when you lift off the brake pedal. The same being true for reverse. I suspect you could get used to it with enough seat time. But it would always be horrid. I found the only way to pull out from a T-junction was to prod the throttle quite hard, then as soon as the vehicle started to move, lift right off, then reapply some throttle. I can only presume, gone are the days of smooth driving?
Despite this horrible oddity, it gets worse. At other times you also get what appears to be a completely dead throttle pedal or lack of response from the gearbox. Usually on 90 degree turns, such as turning into a side road, or pulling out from a Give Way where you could keep rolling at 10-20mph. You go to accelerate in a normal fashion and you get nothing in return. Should you have been foolish enough to pull out in front of something, it will give you quite the puckering I can tell you. This problem is compounded by not being consistent either, because at other times under very similar circumstances, there is no delay at all and it’ll shoot off like a scalded cat!
I decided to experiment a bit with the gearbox and found that normal D or Sport mode made no real difference to this behaviour. And yet there was still one more party trick in store. If you come to a complete standstill, such as being at a roundabout or a junction, don’t hold it on the brake and don’t build any revs. Just stamp on the throttle pedal. My normal expectation would be for the vehicle to move away briskly and swiftly. In the Defender it does not move at all, it waits, then waits a bit longer. Then it eventually decides that it will move. The delay is simply enormous! To the point that it is comically concerning. Never have I driven anything like this.
If you were to give yourself a one, two, three countdown. And went to wide open throttle on three. You’d get to the count of five before you had any form of meaningful forward progression.
I do not know if this problem extends to other vehicles with this powertrain or if the petrol Defender would exhibit the same. But this singular major issue would be enough to turn me away from wanting to buy and own one of these. Hopefully it is just something software related and can be reprogrammed, but it would appear to be a deliberate design choice in how the Defender is intended to drive on the road. Put frankly, I know the ‘Defender’ is being brought into the so-called “Digital age”. However, I still prefer certain controls to have a degree analog feel to them.
I wonder if this could have been the cause?
Post #883786 7th Feb 2021 3:44pm
