![]() | Home > Technical > Electrical/heater 12v acc socket issue |
drakes Member Since: 09 Oct 2009 Location: Hexham Posts: 113 ![]() ![]() ![]() |
My TD5 only has 2 fan speeds unless you count off a a speed
have a look at earth for both
heater switch just in side dash left hand side on the switch acc socket on body try ruing independent earth Last edited by dorsetsmith on 5th Oct 2020 6:11pm. Edited 1 time in total |
Good point and exactly what you said ![]() Thanks DorsetSmith, i do suspect it may be an earthing issue, though I didn’t know whether a resistor issue may be a factor! |
speed 2 it bypass the resistor
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 752 ![]() ![]() ![]() |
Sounds like your ignition switch may be on its way out
