Home > Technical > Electrical/heater 12v acc socket issue
I was just driving home in the td5 had my phone charger in on the acc socket,
Turned the heater fan on and when it was on full speed 3 the 12v socket went off.
Put it on speed 2 and the 12v socket came on, but no fan at all?
Anybody had this before?
All other electrics are fine, horn, lights, wipers, radio, all good.
Any help please?
Post #859956 5th Oct 2020 5:23pm
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
My TD5 only has 2 fan speeds unless you count off a a speed
Post #859958 5th Oct 2020 5:37pm
dorsetsmith
have a look at earth for both
heater switch just in side dash left hand side on the switch
acc socket on body
try ruing independent earth
Post #859961 5th Oct 2020 5:53pm
Good point and exactly what you said Laughing
Thanks DorsetSmith, i do suspect it may be an earthing issue, though I didn’t know whether a resistor issue may be a factor!
Post #859963 5th Oct 2020 6:00pm
dorsetsmith
speed 2 it bypass the resistor
Post #859969 5th Oct 2020 6:39pm
HardCharger
Sounds like your ignition switch may be on its way out
Post #860013 6th Oct 2020 2:03am
