Home > Td5 > Fuel lines |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17451 |
The broken part is an integral part of the pump assembly and as far as I know is not available as a separate part.
5th Oct 2020 6:26pm |
Kris614 Member Since: 30 Nov 2018 Location: Cwmbran Posts: 14 |
Found one...
Click image to enlarge |
5th Oct 2020 6:40pm |
Click image to enlarge if its peace off the end fuel line ( yes it is) make shore you do not loess or brake the clip that lock it in place only supplied with pump Click image to enlarge 7.89mm ID6 Fuel Line Hose Straight Quick Release Male are the ones for the td5 fuel pump Click image to enlarge one one the right |
5th Oct 2020 6:41pm |
Ah, the broken bit is still stuck.in the tank unit, I mistook that for a broken fitting on the sender. Sorry.
5th Oct 2020 9:27pm |
Click image to enlarge TD5 Fuel line repair pump end |
7th Oct 2020 12:52pm |
