Home > Maintenance & Modifications > 3” Td5 Exhaust
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
3” Td5 Exhaust
Just a quick one, does anyone know of a business/individual that can make me a 3” exhaust system without needing the vehicle there? My 90 is off being rebuilt and it’d be ideal just to order in an exhaust to fit whilst everything gets bolted to the new chassis.
Cheers! Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #859623 3rd Oct 2020 7:34pm
camelman
Post #859626 3rd Oct 2020 7:49pm
BaronDefenders
Shall drop them an email! Thanks Thumbs Up Charlie
2002 Td5 90 (SOLD)
Post #859629 3rd Oct 2020 8:14pm
markb110
Baron
You know that a full 3inch is fookin loud in the TD5.
A company called Demand i believe do a valve to lower the noise when you need it, ie not to pee off the neighbours.
https://demandengineering.co.uk/
Predator Styling in Wellington, nr Taughton built mine as a 2inch from the turbo to a cherry bomb behind the rear axle then a 3inch end pipe. He advised against a full 3inch as there was no performance gain
Sounds fantastic but still like a V1 at full chat.
Hope that helps
Post #859636 3rd Oct 2020 8:54pm
BaronDefenders
Yes I know it’ll be offensively loud to anyone in or outside Laughing I’m having the 90 soundproofed, but noise levels don’t bother me too much.
I’ve got a VNT to go on, hence the change from 2.5” up to 3”.
I’d seen Demand’s valved system, which could be quite a good option just for motorway cruising as that’s when it could get annoying. Charlie
2002 Td5 90 (SOLD)
Post #859637 3rd Oct 2020 8:59pm
markb110
That's cool
The TD5 is the best sounding Defender
PS, meant to say that mine is a 2.5 to cherry bomb then the 3inch end pipe
Post #859639 3rd Oct 2020 9:10pm
grafty99
I made my own 3 inch system for my Td5 90. It sounded spectacular but was far too loud for longer distances. I didn't actually find the drone to be the problem but the turbo whistle was deafening. I put a single 20 inch straight through silencer in mine (in approximately the same position as the standard system main silencer) and it's perfect. Thumbs Up
Here is the thread on my 90 (should be page 93)with the videos of the exhaust unsilenced Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #859648 3rd Oct 2020 10:22pm
BaronDefenders
I saw your videos when you did it at the time, sounded awesome!
I hadn’t considered the turbo noise really. So that’s good to know. Hopefully I can have a system made that will be easy to chop and change sections if it ends up being just that bit too loud. Charlie
2002 Td5 90 (SOLD)
Post #859664 4th Oct 2020 7:12am
donmacn
I have a Griffin 3" system on my 300Tdi. Fitted really well, and looks the part. I assume it's also doing its bit to help the engine breathe a bit better.
But I only really posted to say that I was surprised by the noise comment - I haven't found mine noisy at all. Single silencer only, but it just whispers! Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #859695 4th Oct 2020 8:51am
camelman
I also ran a Griffin 3inch on the 110 td5. It wasn't that much noisier than standard. Nice rumble at tick over. Had a bit of resonance at about 70mph on the motorway but after I swapped to disco gearing that moved up to 80+ so not really a problem.
Post #859725 4th Oct 2020 11:16am
BaronDefenders
I’ve sent Griffin an email as it doesn’t appear that you can buy a system from their website/eBay Confused Charlie
2002 Td5 90 (SOLD)
Post #859740 4th Oct 2020 12:32pm
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Just be aware, doing the rounds on Twitter sphere
 Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #859764 4th Oct 2020 2:22pm
