![]() | Home > Maintenance & Modifications > 3” Td5 Exhaust |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3386 ![]() ![]() |
i had one from griffin
http://www.griffinperformance.co.uk/ |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 907 ![]() ![]() ![]() |
Shall drop them an email! Thanks
![]() 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
Baron
You know that a full 3inch is fookin loud in the TD5. A company called Demand i believe do a valve to lower the noise when you need it, ie not to pee off the neighbours. https://demandengineering.co.uk/ Predator Styling in Wellington, nr Taughton built mine as a 2inch from the turbo to a cherry bomb behind the rear axle then a 3inch end pipe. He advised against a full 3inch as there was no performance gain Sounds fantastic but still like a V1 at full chat. Hope that helps |
Yes I know it’ll be offensively loud to anyone in or outside
![]() I’ve got a VNT to go on, hence the change from 2.5” up to 3”. I’d seen Demand’s valved system, which could be quite a good option just for motorway cruising as that’s when it could get annoying. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
That's cool
The TD5 is the best sounding Defender PS, meant to say that mine is a 2.5 to cherry bomb then the 3inch end pipe |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
I made my own 3 inch system for my Td5 90. It sounded spectacular but was far too loud for longer distances. I didn't actually find the drone to be the problem but the turbo whistle was deafening. I put a single 20 inch straight through silencer in mine (in approximately the same position as the standard system main silencer) and it's perfect.
![]() Here is the thread on my 90 (should be page 93)with the videos of the exhaust unsilenced ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I saw your videos when you did it at the time, sounded awesome!
I hadn’t considered the turbo noise really. So that’s good to know. Hopefully I can have a system made that will be easy to chop and change sections if it ends up being just that bit too loud. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 ![]() ![]() |
I have a Griffin 3" system on my 300Tdi. Fitted really well, and looks the part. I assume it's also doing its bit to help the engine breathe a bit better.
But I only really posted to say that I was surprised by the noise comment - I haven't found mine noisy at all. Single silencer only, but it just whispers! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
I also ran a Griffin 3inch on the 110 td5. It wasn't that much noisier than standard. Nice rumble at tick over. Had a bit of resonance at about 70mph on the motorway but after I swapped to disco gearing that moved up to 80+ so not really a problem.
I’ve sent Griffin an email as it doesn’t appear that you can buy a system from their website/eBay
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1029 ![]() ![]() ![]() |
Just be aware, doing the rounds on Twitter sphere
![]() Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
