Home > General & Technical (L663) > “Lift rods”
Cheshire110
“Lift rods”
Apologies if this has been mentioned anywhere else and I missed it.
Any opinions/feedback on the “lift rods” which seem to be popular for the new defender? Particularly in the US; https://lucky8llc.com/collections/defender...-lift-rods
I like the idea of a 1-2” lift, but the fact that you’re kind of “tricking” the car puts me off a little instinctively... Cheers, David
Post #858907 30th Sep 2020 9:13am
Fixed that for you.
These have been popular with the D3/4 boys for some time.
Don't worry about tricking it, it's not like you're sawing it in half and it can still move its feet.
Post #858937 30th Sep 2020 10:52am
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Probably invalids warranty...... Cheers Don.
Post #858962 30th Sep 2020 1:50pm
Tim in Scotland
And your insurance if you don’t declare that you’ve fitted something the car was not designed to have fitted. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #858963 30th Sep 2020 2:10pm
StructuralDefect
United States
So those rods make the vehicle believe it is two inches lower than it is correct? So normal ride height would then be close to off road height I suppose but what happens when you go to off road height? Does it go two inches higher than that? I am also guessing you lose the benefit of access height as well. The warranty thing would be a big concern. 2020 Defender S, P300 in Fuji White w/black ext. pack. Ebony leather heated front/rear seats. Comfort & conv. pack. Towing pack. Cold climate pack. Panoramic roof & expedition roof rack. Classic mud flaps. Fog lights. 19 inch 6 spoke w/off road tires. Clear sight rear view mirror. Sirius XM. Delivery 9/4/20
Post #858973 30th Sep 2020 4:03pm
AndrewS
And a Censored ride 130's have feeling's as well you know Smile
Post #858996 30th Sep 2020 6:04pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
The Land Rover dealers in US are fitting them on new cars as an option so can’t see why it would void the warranty just make sure you ask them and get it in writing before you do.
Post #858997 30th Sep 2020 6:11pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
The US market is different to the Uk/EU in that they operate the network as a separate entity and the warranty situation is very different in some aspects - Porsche have operated their US operation in the same way for years. Using 'what they do in the US' is unlikely to count for anything over here. Rgds.
Chris
Post #859002 30th Sep 2020 6:35pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
The advantage of these are better ground clearance.
The main disadvantages of these are; less suspension compliance and therefore composure offroad due to loss of rebound travel and massively increased wear on driveshafts as permanently running at higher angle not designed for constant running. Remember the initial point of gaining extra ground clearance, well the standard car can do this if it needs to with the extended and super extended modes and while they cannot be accessed by the driver, it is the inbuilt solution when the need arises rather than introduced the permanent compromises as above.
I've seen a video of an L663 attempting a rock climb with these fitted. Its shockingly unstable like its bobbing around on stilts. I'm convinced a standard one would've handled it better due to letting the suspension travel properly. Instagram: l90andy
2006 Land Rover 90 TD5 CSW Silver Edition
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #859038 30th Sep 2020 9:15pm
lohr500
I agree with L90Andy. I don't see what is gained by fitting them as the air suspension system is designed to give increased body height when needed off road.
The higher centre of gravity when used on the road must surely upset the handling and stability.
Post #859057 1st Oct 2020 6:58am
jst
Ground clearance on these is good anyway. No diff exposed in beam axle for starters.
Higher you go the narrower the track and as already mentioned the greater the angles on drivetrain components.
LR R&D budget is pretty big, there must be some good founding behind 90s only in extended and super extended modes.......
We have one particular climb at work, rrvse, super extended, if they take the wrong turn on the way up, fns cv goes bang Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #859079 1st Oct 2020 8:35am
Cheshire110
Thanks for all the input guys - I think most of you have the same instincts as me - I’m sure the standard range of height options will be more than enough for what we all want to use the vehicle for, to be honest. Cheers, David
Post #859101 1st Oct 2020 10:14am
AndrewS
Back in the day we compared a standard D3 against a rod lifted D3. The standard car was mine. The course was at Yarwell Quarry and very extreme. The rod lifted car failed the course, it was bouncy and its wheels were off the ground alot. My standard car had better suspension travel kept its tyres on the deck longer thus got grip, there is a video over on the D3/4 site somewhere. 130's have feeling's as well you know Smile
Post #859150 1st Oct 2020 4:34pm
jst
Weight was lower and it was actually working within its design parameter!
Only time I see extra lift being advantageous ruts, approach angle and ramp over. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #859157 1st Oct 2020 5:24pm
GreenMonster
United States
Just search YouTube for 4x4 rollovers and you’ll see plenty of lifted rigs bouncing over onto their roofs. Some non-lifted rigs as well to be sure, but it doesn’t take an automotive engineering degree to see what lifts can do to handling.
Post #859218 2nd Oct 2020 3:00am
