Home > My Defender > PHEV 110 |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2760 |
Finally took the plunge and have ordered a PHEV 110.
X-Dynamic SE, Hakuba Silver, Off Road pack. Should be a beast and can’t wait to get some adventures under her belt! Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
27th Sep 2020 12:44am |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
The steering wheel seems to be on the wrong side, better see if you can amend your order
27th Sep 2020 7:43am |
Hehe hopefully they get it RIGHT at the factory... Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
27th Sep 2020 8:33am |
Nope have gone for the P400e plug in hybrid (PHEV) - was announced/able to build on the site about a week or two ago. Only in X-Dynamic trim if you missed it... Click image to enlarge Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
27th Sep 2020 8:35am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
It’s the same system as the Velar, RRS and FFRR so a full PHEV, all the other engine options will become MHEVs in the next few months, you will be able to order them from November as far as I know. Only the 6 cylinder P400 is an MHEV at present. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
27th Sep 2020 8:36am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1426 |
Yes, I had missed the announcement of the PHEV.
Shame it's only in the top spec trim. I'll go and have a read up on it. Thanks. |
27th Sep 2020 8:46am |
I’ve just specced up a PHEV 110 X Dynamic in SE and S trims on the configurator but it’s only available as an X Dymnaic and not in non -Dynamic versions. Interesting that on the configurator pictures of the back you get the recovery eyes shown as fitted every time I try to build an X-Dynamic so possibly there is other equipment in the X-Dynamic pack that justifies the higher cost. Cheshire110’s series of pictures also show them fitted to his spec. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
27th Sep 2020 8:52am |
Yes I guess similar to how the RR PHEV was only available in Autobiography at first, they want a little more money off the early adopters...
X-Dynamic comes with quite a bit of spec including all the gloss black body panels at the bottom, a grey (rather than silver) front and rear grille/scuff plate, privacy glass, keyless entry and some other stuff as standard, the exposed rear recovery eyes, etc... Probably not ‘worth it’ but gives you just enough to justify the extra c.£2k that you’re forced to spend. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
27th Sep 2020 9:05am |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2163 |
Very nice but sure its not just me that was excited to finally see a 'classic' in build........or not.......
27th Sep 2020 9:48am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
I can see that someone has reported your post
I can see them now sat at their PC wearing wooly underpants, a painting on the wall behind them showing a flat earth. 130's have feeling's as well you know |
27th Sep 2020 1:39pm |
