![]() | Home > Puma (Tdci) > Slick shift or Shift R? |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 186 ![]() ![]() ![]() |
Awesome looking vehicle you have there Madfrankie.
I'd also be interested in replies from those with either. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1986 ![]() ![]() ![]() |
Can only comment on what i have which is the slick shift, good quality, well packaged, works well, easy to fit, good improvement on the standard, very helpful installation video. In essence an nice modification and worth the money.
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20759 ![]() ![]() |
Slick shift V2 here. Really pleased with it.
One piece design and works really well. Kit feels to me like it should have out of the factory. Highly recommended. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 123 ![]() |
@Steve - does the lever position foul - or is it close to the cubby, I am leaning towards the Shift R but Slick Shift ‘appears’ to provide more clearence?
No it shouldn’t do, it’s much the same as standard and I didn’t notice any difference really other than a very small amount higher I think but nothing that you’d worry about or notice.
It feels brilliant, I lubed mine right up with lots of Castrol lithium grease. It doesn’t feel heavier either and it’s definitely very smooth. It isn’t cheap no, but it is definitely worth it and feels like it should have done from the factory. On mine, with the original fitting I went to lube it and found the nylon ball had cracked. So I was lucky it didn’t let me down, so as it was replacement time I thought I may as well upgrade. Decently up there with the best mods I’ve done. ![]() ⛽️🛢️⚙️🧰💪 |
Thanks Steve
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3355 ![]() ![]() ![]() |
I fitted the Shift R v2 and it doesn't foul the cubby but will hit my bottle of water in the cupholder. I'm not sure if that is the case with the Slick shift but for gearchanges I didn't notice anything between them. Either will be an improvement on stock.
If you haven't already fitted a LOF power spring, I'd definitely recommend. WARNING. This post may contain sarcasm. |
madfrankie Member Since: 10 Oct 2016 Location: Hertfordshire Posts: 356 ![]() ![]() ![]() |
All, I fitted the Shift Rv2 tonight and love it.
I’ll be getting the spring next week. Thanks to all. "Of Course, Of course, I ain't asking . I'm telling!!" |
Feels good doesn’t it.
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
So why Shift R over Slickshift? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Bonjour Monsieur Grenadier,
In the end in came down to anecdotal evidence ( recommendations) and ease of fitting. The Shift R came complete and literally just “popped in” Really did take more time to remove the mats and gubbins. I couldn’t be arsed with all the fitting up that came with the slick shift. It may suit some of the more technical guys on the forum but I’m a “K.I.S.S.” Type of guy and four bolts out then four bolts in Works for me. That said there REALLY does seem to be nothing else that separates them ( price not withstanding) once fitted. And it is a truly worthwhile upgrade. L.O.F. Spring next "Of Course, Of course, I ain't asking . I'm telling!!" |
Does anybody have one of these fitted with a raised cubby, particularly the Shift R , I have the mudstuff sub locker and if the shift r hits a bottle in the cubby would it hit a raised cubby?
trooper Member Since: 11 Mar 2014 Location: west sussex Posts: 102 ![]() ![]() ![]() |
Can I fit a SHIFT R or SLICK SHIFT to my 2001 TD5 without problems.
Peter |
I don't think it would hit the cubby but I'm not sure if you could use the cupholder if it was raised. WARNING. This post may contain sarcasm. |
