Home > Puma (Tdci) > Slick shift or Shift R?
madfrankie
England 2007 Defender 90 Puma 2.4 SW Stornoway Grey
So when I said I was done....
I am wanting to sharpen up the gear change and although I have seen various posts re pros and cons on both,
I was hoping to carry out a straw poll on the forum as to which is best (Cost not withstanding)
I know lots of you have fitted one or the other.
Look forward to your comments. "Of Course, Of course, I ain't asking . I'm telling!!"
Post #857427 22nd Sep 2020 2:50pm
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Awesome looking vehicle you have there Madfrankie.
I'd also be interested in replies from those with either.
Post #857429 22nd Sep 2020 3:07pm
bear100
Can only comment on what i have which is the slick shift, good quality, well packaged, works well, easy to fit, good improvement on the standard, very helpful installation video. In essence an nice modification and worth the money.
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #857431 22nd Sep 2020 3:14pm
Slick shift V2 here. Really pleased with it.
One piece design and works really well.
Kit feels to me like it should have out of the factory. Highly recommended. WeWillWin🇬🇧🇺🇸
Post #857445 22nd Sep 2020 4:01pm
cold
@Steve - does the lever position foul - or is it close to the cubby, I am leaning towards the Shift R but Slick Shift ‘appears’ to provide more clearence?
Post #857450 22nd Sep 2020 4:49pm
No it shouldn’t do, it’s much the same as standard and I didn’t notice any difference really other than a very small amount higher I think but nothing that you’d worry about or notice.
It feels brilliant, I lubed mine right up with lots of Castrol lithium grease.
It doesn’t feel heavier either and it’s definitely very smooth.
It isn’t cheap no, but it is definitely worth it and feels like it should have done from the factory.
On mine, with the original fitting I went to lube it and found the nylon ball had cracked.
So I was lucky it didn’t let me down, so as it was replacement time I thought I may as well upgrade.
Decently up there with the best mods I’ve done.
Thumbs Up WeWillWin🇬🇧🇺🇸
Post #857478 22nd Sep 2020 7:25pm
cold
Thanks Steve Thumbs Up
Post #857481 22nd Sep 2020 7:49pm
Zed
I fitted the Shift R v2 and it doesn't foul the cubby but will hit my bottle of water in the cupholder. I'm not sure if that is the case with the Slick shift but for gearchanges I didn't notice anything between them. Either will be an improvement on stock.
If you haven't already fitted a LOF power spring, I'd definitely recommend. WARNING.
Post #857486 22nd Sep 2020 8:10pm
madfrankie
All, I fitted the Shift Rv2 tonight and love it.
I’ll be getting the spring next week.
Thanks to all. "Of Course, Of course, I ain't asking . I'm telling!!"
Post #858284 26th Sep 2020 6:59pm
Feels good doesn’t it. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #858299 26th Sep 2020 8:23pm
Grenadier
Thanks to all.
So why Shift R over Slickshift? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #858333 27th Sep 2020 7:13am
madfrankie
Bonjour Monsieur Grenadier,
In the end in came down to anecdotal evidence ( recommendations)
and ease of fitting.
The Shift R came complete and literally just “popped in”
Really did take more time to remove the mats and gubbins.
I couldn’t be arsed with all the fitting up that came with the slick shift.
It may suit some of the more technical guys on the forum but I’m a “K.I.S.S.” Type of guy and four bolts out then four bolts in
Works for me.
That said there REALLY does seem to be nothing else that separates them ( price not withstanding) once fitted.
And it is a truly worthwhile upgrade.
L.O.F. Spring next "Of Course, Of course, I ain't asking . I'm telling!!"
Post #858343 27th Sep 2020 8:52am
cold
Does anybody have one of these fitted with a raised cubby, particularly the Shift R , I have the mudstuff sub locker and if the shift r hits a bottle in the cubby would it hit a raised cubby?
Post #858367 27th Sep 2020 10:19am
trooper
United Kingdom 2002 Defender 90 Td5 HT Tamar Blue
Can I fit a SHIFT R or SLICK SHIFT to my 2001 TD5 without problems.
Peter
Post #858370 27th Sep 2020 10:28am
Zed
I don't think it would hit the cubby but I'm not sure if you could use the cupholder if it was raised. WARNING.
Post #858378 27th Sep 2020 11:01am
