Home > Technical > Non starter!!
markieboy
2007 Defender 110 Puma 2.4 USW Java Black
Non starter!!
Went out to my 2007 tdci today, went to start it and on turning the key all I got was clicking sound from under passengers seat ( left hand drive) , no sound of starter at all! After while of trying no power even for central locking! I've taken out battery and put on charge for night! Noticed on battery it has vent tube , is this standard? Also what is average age a battery will last ? I think this is the original battery! Any ideas what the cause is? Is it just battery or could it be something else?? Thanks in advance for any help!
Post #85766 23rd Aug 2011 6:35pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Could have been a loose battery terminal, or loose earth lead to chassis, battery could last between 4 and 7 years so may just need a new one, do you do a lot of short journeys ?
Post #85768 23rd Aug 2011 6:38pm
Bobble
Mine's a TD5 but had exactly the same symptom last week.
Very simple - loose connection to the starter solenoid (the 12v lead, not the hoofing great cable direct from the battery, althought that might be worth a look too)
Crimped it up a bit with pointed pliers, job done. Probably worth a look just to eliminate it from your fault finding. Also try swapping the start relay (the one which you can hear clicking) as this might not be latching fully.
Post #85772 23rd Aug 2011 6:47pm
Glynparry25
Deffo low battery power.
From my time in Poland, you have VERY cold winters- so there is a very good chance that the battery is completely goosed. Try charging it and then discharge test it. The LR batteries have vents on them Wink
Glyn Dog Sheep
Post #85773 23rd Aug 2011 6:49pm
Bobble
Glynparry25 wrote:
in Poland,
Oops, missed that bit Embarassed Yep, try the battery first, cold will have taken its toll.
Post #85775 23rd Aug 2011 6:54pm
markieboy
Defender hasn't been used recently, as I've been away for work! Only owned it for 2 months so not sure of it's past use! Thanks to all of you who replied, first thing tomorrow I'll be outside sorting it out! Thanks everyone!
Post #85777 23rd Aug 2011 7:01pm
kingofthesparks
Due to the age of the battery I would be tempted to buy a new one anyway, at least it will eliminate one item and save it letting you down in future , buy a good one with 3 years guarantee Thumbs Up
Post #85778 23rd Aug 2011 7:07pm
markieboy
As suggested by 'king of the sparks' , a new battery ! Already decided I will get new one tomorrow as don't need it letting me down in the winter! An old battery and -15 , - 25 don't go great together!
Post #85781 23rd Aug 2011 7:18pm
markieboy
Just to finish the story!! After battery on charge all night, reconnected and it fired into life on first turn of key! Have been out and treated my defender to brand new battery ! Thanks to all of you for your help! Great to know good people out there willing to share there knowledge with you!
Post #85870 24th Aug 2011 10:33am
