Home > Technical > Internal hoop
jst
Internal hoop
I recall a while back a discussion on a single internal fixed roll Iver protection hoop that goes behind the drivers seat in a 1100 station wagon. Does anyone know the manufacturer? Supplier.
Embarrassing I do have one, just no markings on it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #856345 16th Sep 2020 8:18pm
The Safety Devices full cage has an internal hoop in that position, there's no reason it couldn't be installed on its own.
Post #856391 16th Sep 2020 10:16pm
jst
cheers, I googled sd but couldn't give just the hoop, so thought it was probably someone else's! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #856471 17th Sep 2020 12:06pm
I'm not saying the one you're thinking of is necessarily SD, but the SD one is the only one I know of that fits there.
Post #856478 17th Sep 2020 12:39pm
Chicken Drumstick
Just remember internal cages are a common source of injuries. Unless you are strapped into the seat with a harness and wearing a crash helmet.
Post #856489 17th Sep 2020 1:17pm
Litch
"behind the drivers seat in a 1100 station wagon."
Bet that has one hell of a turning circle, is it articulated? Question Very Happy Laughing ONE LIFE, GET IT!
Post #856523 17th Sep 2020 5:12pm
jst
it is the one, just cant find it! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #856524 17th Sep 2020 5:16pm
jst
yep, am, well aware thank you Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #856525 17th Sep 2020 5:16pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #856623 18th Sep 2020 8:14am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Hi James
The standalone internal hoop part no. Is RBL115 4SSS-B if you have no headlining and RBL033 4SSS-B with headlining. You change the 4 for a 5 if you want the diagonal strut brace. This can be connected at the top on both sides to an external cage with adapter brackets. This is the same hoop used on the 90’s with a bulkhead removal that was factory on my 50th and I had on the TD5 90
The full internal external 110 cage has a different internal hoop that I suspect has no individual part number. When I got my p38 parts from SD you could get anything that was in a kit individually even if it didn’t have a part number, but that was almost twenty years ago before they changed hands several times. 🙄
Post #856636 18th Sep 2020 11:09am
I have a P&P internal hoop in my 110, it bolts through the roof to mate up with the external bits, but I see no reason why you couldn't use a couple of blank plates on the outside to mount it. It also bolts up the upper seatbelt fixings on the B pillars.
Having said that, I don't know how strong it would be on its own; if you rolled directly onto your roof, maybe OK (although it doesn't have a diagonal so would crush anyway) but if you were sliding along a road on your roof, there'd be no lateral support frontways or backwards (that comes from where it's bolted to the outside bit of the cage.
Think you'd be better with a complete internal passenger cage. which I think SD and P&P do.
Shout if you want any pics of mine James
Post #856666 18th Sep 2020 2:29pm
