Home > V8 > 3.5 to 3.9 - the long term re-engine thread
Page 1 of 3 123>
Ranger 6
United Kingdom 1988 Defender 90 V8 Petrol CSW Rimini Red
This is going to be a long term thread - I've found a bare 3.9 which may have a head gasket issue.
This is going to be cleaned, stripped and crack tested before a careful build into a 'refreshed' engine to replace the 3.5.
It will have an improved cam, at the same time retain the carbs and from the outside be indistinguishable from the original motor, just with more power and torque. 90 V8 CSW - 1988
Post #856055 14th Sep 2020 7:27pm
L110CDL
Nice, i hope we are going to have plenty of pic's of the progress please Very Happy Clayton.
Keeper.
Post #856061 14th Sep 2020 7:46pm
Ranger 6
Well, here's the first
The world's first X3 3.9 V8 hybrid..... Laughing The engine stand comes tomorrow so will actually be able to take it out.
Then comes the cleaning Very Happy
 90 V8 CSW - 1988
Post #856066 14th Sep 2020 7:59pm
muddypaws
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
I tried the hybrid route with a D3 - fitted in easily Very Happy
[img]https://www.defender2.net/gallery/albums/userpics/14272/normal_V8Con.bmp[/img] Richard
Defender 90 SVX
Post #856080 14th Sep 2020 8:29pm
Ranger 6
Laughing a bit different to mine!!
The next question, assuming the block is good and sound - which cam?
It's an improvement over the original low compression 3.5, but I don't want a standard 3.9 cam.
It's used off-road so I don't want a rev hungry high lift cam - what's the best for low end torque? 90 V8 CSW - 1988
Post #856081 14th Sep 2020 8:31pm
muddypaws
'twas tricky getting it in/out without wrecking the headliner with the hoist! Richard
Defender 90 SVX
Post #856082 14th Sep 2020 8:32pm
L110CDL
Thanks for the pic Thumbs Up
I'm no expert on engine building, but love watching them being rebuilt and i'm sure someone with the answer will be along soon Thumbs Up Clayton.
Keeper.
Post #856091 14th Sep 2020 9:17pm
Will you be running auto or manual?
Post #856132 15th Sep 2020 8:41am
Avelingporter
Why don't you ask John Eales or RPi about the cam choices. They will have for sure been and done that with cams, so should be best placed to recommend a cam profile to suit what you are after.
Post #856140 15th Sep 2020 9:59am
Huttopia
Quite a lot of cleaning by the looks of it! Was it set on fire?! Very Happy .
Would it be possible to build it out to a 4.6 using Range Rover parts?
Post #856141 15th Sep 2020 10:00am
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
4.6 crank journals are larger than the 3.9/3.5, and amongst other things the front end is different so that's just a whole load more work. JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #856144 15th Sep 2020 11:05am
Be sure it is a 3.9, a mate had a 3.9 in his race buggy and after a few seasons he decided to rebuild it.. turned out it was a 3.5 with 3.9 plenum Laughing
Post #856158 15th Sep 2020 1:27pm
muddypaws
I used to live just down the road from John Eales; an extremely helpful chappie who knows everything about the RV8. He works from an old mill in Claybrooke that is a treasure trove of RV8 parts Richard
Defender 90 SVX
Post #856166 15th Sep 2020 3:36pm
Ranger 6
L110CDL wrote:
...I'm no expert on engine building....
Neither am I - this will be the first, but after reading many threads I can drop words in like 'plastiguage' and other apparently technical stuff Laughing
Manual - it's (hopefully) going to be a straight swap for the 3.5 that the factory put in it
Already done - it came out of a Range Rover and has the little cut outs in the inlet ports where the injectors sit. The other part is the CR stampede in the block. See - that makes me sound like an expert! Mr. Green
For the other questions - yes, cam - I've heard RPi can be a bit condescending when consulted for advice. I may try John Eales.
No it's definitely not going to change capacity, this is a budget build and I'm really hoping there won't be any engineering costs other than a crack test and some skimming to true the block and heads 90 V8 CSW - 1988
Post #856231 15th Sep 2020 9:43pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
You could speak to Roland at ACR (I know Greeni and others have had a good experience using him) re the cams if you can't get hold of John as I understand he's pretty well booked up at the moment.
I've found RPi and V8 Developments to be knowledgeable but pretty difficult to deal with, I purchased a GEMS manual flywheel from one of the guys at the latter last week only after his colleague tried to flog me the very same one for £100 more. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #856249 16th Sep 2020 6:16am
Page 1 of 3 123>
