![]() | Home > Td5 > Ignition switch live feed in the rear? |
Not as standard, no. If you've got towing electrics then there will be one as part of that loom that you could tap into but nothing as convenient as the purple wire for a permanent feed. Darren
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5920 ![]() ![]() ![]() |
Cheers. I have standard towing electrics. 7 pin. Shame, means i need to run a new power feed for the camera. Not wanting to use the reverse light as i plan on flicking to camera while driving or towing cars on the trailer. 1999 Defender TD5 110
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6651 ![]() ![]() ![]() |
Ignition feed (white/green) present on plug for the rear door (for rear wiper).
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
Post 2002, there's a white/green ignition-switched live to the rear wiper motor.
This can be accessed at the 6-way sealed connectors between the chassis harness and the rear door harness. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Pre-2002MY (old style door) it's there as well. On the 4 pin plug (3 used), the feed to the park switch for auto-parking.
Ah, forgot about the wiper motor! Sorry! Darren
Thanks chaps. I hadnt considered the rear wiper as an option 1999 Defender TD5 110
Found the wire. Its green by the time it gets to the wiper motor. 1999 Defender TD5 110
