![]() | Home > Technical > Non starting possible fuel issue |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17621 ![]() ![]() ![]() |
What fuel rail pressure do you get when cranking?
P0335 Crank position sensor A intermittent
Not tested driver side flywheel end at the top Check plug and wiring to the Crank position sensor may be damage U3000 Faulty Control Module Control Module harness is open or shorted Control Module circuit poor electrical connection |
A failed or intermittent crankshaft position sensor would certainly cause the sudden death symptom, and would also cause the failure to start symptom since the injectors won't fire unless the ECM can determine when to fire them. Certainly the first thing to check given the presence of that DTC.
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
Inspected the Crank Position sensor wiring but could not see anything. Got continuity from either of the pins to earth. Cleaned refitted and tried to start. Engine fired a couple of times but would not run. Retried to start but just cranking and not firing.
Its getting dark, but noticed the brake lights are permanently on. Could be coincidence, but wonder if it is relevant. I think I will unplug the ECU plugs and see if I can individually prove the integrity of the yellow/purple and green wires from the crank sensor in the morning. |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 558 ![]() ![]() ![]() |
Just take a look, if there's any juice coming out of the injectors |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 751 ![]() ![]() ![]() |
The brake lights are on? Wasn't there something on this before about the brake lights and engine trouble? I'm sure others will chime in soon. I can't really do a proper search here on the forum right now as my connection is spotty and I'll be lucky if this will post. Something worth looking into. |
Turned out the brake lights were a red herring as I replaced the pedal switch as it was faulty. Looks like I may have a short on the Crankshaft sensor wiring so I am rewiring this tomorrow.
