Home > Maintenance & Modifications > Filling in Body Holes when inward facing seats removed |
If you don’t need to use the holes again the usual solution is to take an off cut of aluminium and bond it to the underneath Of the panel then probably best to seal around the off cut just in case. Ray
11th Sep 2020 7:31pm |
LandyHelp Member Since: 09 Aug 2020 Location: caribbean Posts: 13 |
OK so a body shop needs to get involved then. Sounds a bigger job than I anticipated. It does need waterproofing though.
Thanks. |
11th Sep 2020 7:35pm |
Not really, it’s only glueing a square of aluminium to the underneath of the hole then when set run some sealer around the edge of the plate. Ray
11th Sep 2020 8:07pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Stainless nut/bolt with penny washers and rubber gasket? Rgds.
Chris |
11th Sep 2020 8:29pm |
OK sounds simpler than I thought. Phew. I will try that.
11th Sep 2020 8:30pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2038 |
Rubber grommets?
11th Sep 2020 9:57pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
I had success by just attaching anti slip tape from the inside (cleaner surface). Perhaps can apply a good automotive sealant from the outside as extra preventative measure against leaks. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
12th Sep 2020 12:32am |
rdavisinva Member Since: 11 Sep 2020 Location: Chesapeake Posts: 5 |
I watched this video and in 2:42 the topic is filling holes.
This guy used "Chemical Metal" with great success. https://youtu.be/qiN-xdIzE1o |
12th Sep 2020 12:57am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
When I removed the rear seating in mine I sealed all the holes with big headed rivets and PU sealer. On the big holes I also used a SS penny washer on the other side. The holes are waterproof, practically flat inside, and can be reopened by just drilling the river out should it be required.
12th Sep 2020 3:17am |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 735 |
I just got new screws and screwed them on the same spots down flat. No fuss, no mess. All good so far. (I think I now jinxed myself)
12th Sep 2020 6:47am |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 520 |
These with a normal round head pozi bolt through them :
https://www.ebay.co.uk/itm/190581016954 2017 Range Rover L405 Vogue SE V8 Diesel #16 Land Rover 110 300 TDI |
12th Sep 2020 7:42am |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 817 |
I use these to fill holes low profile large head and look neat and tidy -
N Click image to enlarge |
12th Sep 2020 8:14am |
It sort of depends on what sort of finish you want inside. When I did a similar thing to my old 90, I planned to soundproof and carpet the interior and so wanted a flat finish. I therefore bonded some small pieces of aluminium to the underside with Sikaflex, much as Ray suggested. It's a very quick and easy job:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Sep 2020 9:34am |
Martyn668 Member Since: 17 Mar 2013 Location: Cambridgeshire Posts: 135 |
From my build thread here https://forums.lr4x4.com/topic/95342-how-t...e-puma-90/ when I took out the sideways-facing rear seats to replace with forward facing seats:
At around this stage (or indeed at any point up to here when paint was drying or I couldn't make any other progress), I started filling up the original holes. I did this by using some thin (0.2mm) aluminium penny washers bought off Ebay. I first painted them in primer, then Hammerite, and then applied one underneath, and one above each hole and then riveted them in place. To hold them in place while I was riveting, I used a dab of Tigerseal (also to waterproof the “repair”). |
15th Sep 2020 9:35pm |
