Home > Maintenance & Modifications > Filling in Body Holes when inward facing seats removed
LandyHelp
Does anyone have any tips on this matter. I have a 110 and decided to remove the inward facing 3rd row seats. I need to fill the holes where the seats were bolted in to the body. I cannot seem to find any plastic screws with a rubber seal to close the holes up. Any ideas anyone how I can close these holes up?
There are similar holes in the front footwell where the seats are attached via a plastic screw to hold down the carpet.
A coin with with some expoxy might be an option!
Post #855545 11th Sep 2020 7:28pm
mk1collector
If you don’t need to use the holes again the usual solution is to take an off cut of aluminium and bond it to the underneath Of the panel then probably best to seal around the off cut just in case. Ray
My build thread
Post #855546 11th Sep 2020 7:31pm
LandyHelp
OK so a body shop needs to get involved then. Sounds a bigger job than I anticipated. It does need waterproofing though.
Thanks.
Post #855548 11th Sep 2020 7:35pm
mk1collector
Not really, it’s only glueing a square of aluminium to the underneath of the hole then when set run some sealer around the edge of the plate. Ray
My build thread
Post #855554 11th Sep 2020 8:07pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Stainless nut/bolt with penny washers and rubber gasket? Rgds.
Chris
Post #855560 11th Sep 2020 8:29pm
LandyHelp
OK sounds simpler than I thought. Phew. I will try that.
Post #855561 11th Sep 2020 8:30pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Rubber grommets?
Post #855567 11th Sep 2020 9:57pm
Dinnu
I had success by just attaching anti slip tape from the inside (cleaner surface). Perhaps can apply a good automotive sealant from the outside as extra preventative measure against leaks. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #855569 12th Sep 2020 12:32am
rdavisinva
I watched this video and in 2:42 the topic is filling holes.
This guy used "Chemical Metal" with great success.
https://youtu.be/qiN-xdIzE1o
Post #855570 12th Sep 2020 12:57am
landy andy
When I removed the rear seating in mine I sealed all the holes with big headed rivets and PU sealer. On the big holes I also used a SS penny washer on the other side. The holes are waterproof, practically flat inside, and can be reopened by just drilling the river out should it be required.
Post #855573 12th Sep 2020 3:17am
HardCharger
I just got new screws and screwed them on the same spots down flat. No fuss, no mess. All good so far. (I think I now jinxed myself) Thumbs Up
Post #855584 12th Sep 2020 6:47am
Grouse
These with a normal round head pozi bolt through them :
https://www.ebay.co.uk/itm/190581016954 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI
Post #855601 12th Sep 2020 7:42am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
I use these to fill holes low profile large head and look neat and tidy -
N
Post #855605 12th Sep 2020 8:14am
It sort of depends on what sort of finish you want inside. When I did a similar thing to my old 90, I planned to soundproof and carpet the interior and so wanted a flat finish. I therefore bonded some small pieces of aluminium to the underside with Sikaflex, much as Ray suggested. It's a very quick and easy job:
 Darren
Post #855623 12th Sep 2020 9:34am
Martyn668
From my build thread here https://forums.lr4x4.com/topic/95342-how-t...e-puma-90/ when I took out the sideways-facing rear seats to replace with forward facing seats:
At around this stage (or indeed at any point up to here when paint was drying or I couldn't
make any other progress), I started filling up the original holes. I did this by using some
thin (0.2mm) aluminium penny washers bought off Ebay. I first painted them in primer, then
Hammerite, and then applied one underneath, and one above each hole and then riveted
them in place. To hold them in place while I was riveting, I used a dab of Tigerseal (also to
waterproof the “repair”).
Post #856229 15th Sep 2020 9:35pm
