![]() | Home > Series Land Rovers > My Series III |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
Realised I've not updated anything for ages...
In answer to question earlier its brush / roller painted using paint from paddocks. I sorted the front lights with new bowls, bulbs, lenses etc.. ![]() Click image to enlarge Due to a big garden project any work on the series has been put on hold. So my single garage at back of house has been dismantled and my updated picture I hope will show the new garage... Currently ![]() Click image to enlarge On a positive note I have entered my first show of 2021 ![]() |
CA_Series_IIa Member Since: 19 Oct 2021 Location: California Posts: 7 ![]() ![]() ![]() |
Just wanted to say that blue (marine blue?) looks really nice with the galvanized trim pieces! My Series has painted trim and one day I'd like to get back to galvanized. I'm also considering painting it marine blue so these pictures are great!
^ Thanks
![]() New addition to the fleet.... Willow, She's been out in the 110 not the Series as yet. ![]() Click image to enlarge |
Not posted for ages, new garage has been built... you may have seen my other thread on this.
So that's nice having somewhere to keep dry while working on. ![]() Click image to enlarge We have just been on our first show of 2022 and was invited on the Main ring by the Chief Steward @ the Royal county Cheshire Show. Some pictures from the show, Willow the Cockerpoo approves ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge claim to fame, main ring and was 'interviewed' about the car ![]() ![]() Click image to enlarge |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 ![]() ![]() ![]() |
I've been looking since Christmas and found a good one yesterday, deposit paid and it gets delivered next week (it was too much of a pain to bus - train - tube - bus to go and get it).
Looking forward to it. ![]() Click image to enlarge |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17680 ![]() ![]() ![]() |
Looks smart, but what happened to the wipers?
(It looks as though someone has either fitted a late Defender wiper motor or fitted the wheel-boxes upside down, since they are parked at the wrong end of the sweep). |
I did notice that but figured that they've switched it off while they're running? Important thing was the clean chassis, running gear and bodywork.
Thanks for the comment though, I'll see if I can get them to sort it before delivery. Last edited by AndyS on 18th Apr 2023 1:11pm. Edited 1 time in total |
I have to say that it does look very tidy in the photo. If it is as good as it looks, you have done well.
![]() Click image to enlarge Agricultural they say! It's more like a Route Master bus. 🤣 Annoyingly I bent the drivers step while reversing up the drive (Trucksaurus doesn't have side steps so I forgot about them). If anyone wants an 'as new' passenger side step let me know. It does actually look new or recently new so might be useful to someone. It needs lots of little jobs (dealer did the wipers) like none of the keys match and it has a radio and a rear view mirror - what's the point? So they'll come out and it needs a spare wheel, has the bulkhead fittings but no wheel. Engine sounds a bit tappy and the manuals have just arrived so will look at that. Good fun though. Might look at getting the steering sharpened up a bit and a disk brake conversion. |
Looks very Smart
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 765 ![]() |
Smart looking truck👍
The only problem with a disc brake conversion is that with most kits you will loose the original wheels and have to use aftermarket ones such as eight spokes or modulars. You may possibly get away with Wolf rims. The only kit that works with series rims is the Paul Hastee kit which is basically a new swivel housing casting with two lugs and uses standard 90 discs and calipers. It is much more expensive than others such as Zeus and I’m not even sure if it’s being imported since Brexit. I would like to put a disc conversion on the front of my 1958 88” but I want to retain my one tonne rims. |
Looks good. I presume that you have a front number plate? The wipers look so much better already.
Personally I would not bother with a disk brake conversion, the standard 10" drums work just fine when correctly adjusted and you just need to remember that you are driving a vehicle with 10" drum brakes. Does it have a brake servo? If not, you could fit one (I can't remember if the SIII SWB had one fitted as standard, I suspect by then they did). I've never felt the need for a brake upgrade on any of my Series Ones (10" drums, no servo) and in the past I used to tow up to 3.1/2 tons regularly with them (slowly, it must be admitted). |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3514 ![]() ![]() ![]() |
Seen once a Series with a 200tdi/earlier swivels/hubs and hence discs/calipers bolted to a series axle tube. But have no details of how it was done, especially what half shafts were used. I am sure the spring seats on the axle have to be rotated or wedged to allow the track rod to go over the springs, so get the diff nose up same as on a Defender. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Blackwolf, yes there is a front number plate but I removed it from the picture (only while the paperwork is coming through, I don't know why I do that but it doesn't feel mine until I've got a load of envelopes for it). Thanks for the info on the brakes, I've not looked through the paperwork yet, there are a few receipts and for all I know, it might have new shoes that need bedding in.
Probably a silly question but does it have a choke? I can't find one! It's an '83 2.3 diesel. |
