Home > Maintenance & Modifications > Brain freeze
Ben-9090
Brain freeze
Sorry I’m having a brain freeze. What’s the gasket called where the prop goes into the rear diff. Is it a diff pinion oil seal? Thanks Ben
Post #854440 5th Sep 2020 5:56pm
Pretty much Thumbs Up
Post #854445 5th Sep 2020 6:12pm
Ben-9090
Thumbs Up
Post #854448 5th Sep 2020 6:16pm
Yes, except it is not a gasket, it's an oil seal! Rolling with laughter
Post #854449 5th Sep 2020 6:22pm
Ben-9090
Told you I was having a brain freeze!
Post #854460 5th Sep 2020 7:00pm
Pilgrimmick
Normally a sponge! 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #854461 5th Sep 2020 7:04pm
If you’ve got a pinion oil seal leak, check your prop UJ’s.
I had the seal on mine replaced many times and kept leaking, then I checked the UJ’s and the rearmost UJ on the rear prop had failed which was causing it.
I couldn’t tell really either until the prop was off, and a single UJ bearing cup had failed completely with no roller bearings left. The rest were fine but still worn.
Just thought I’d mention it.
Thumbs Up WeWillWin🇬🇧🇺🇸
Post #854475 5th Sep 2020 7:45pm
Ben-9090
Good point. Most jobs start nice and simple but then end up doing another 3 to sort out the 1st job.
Post #854476 5th Sep 2020 7:52pm
