Home > Maintenance & Modifications > Brain freeze |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
Pretty much
5th Sep 2020 5:12pm |
Ben-9090 Member Since: 05 Apr 2020 Location: Norfolk Posts: 8 |
5th Sep 2020 5:16pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17346 |
Yes, except it is not a gasket, it's an oil seal!
5th Sep 2020 5:22pm |
Told you I was having a brain freeze!
5th Sep 2020 6:00pm |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 |
Normally a sponge! 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
5th Sep 2020 6:04pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20294 |
If you’ve got a pinion oil seal leak, check your prop UJ’s.
I had the seal on mine replaced many times and kept leaking, then I checked the UJ’s and the rearmost UJ on the rear prop had failed which was causing it. I couldn’t tell really either until the prop was off, and a single UJ bearing cup had failed completely with no roller bearings left. The rest were fine but still worn. Just thought I’d mention it. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
5th Sep 2020 6:45pm |
Good point. Most jobs start nice and simple but then end up doing another 3 to sort out the 1st job.
5th Sep 2020 6:52pm |
