Home > Puma (Tdci) > Is this THE Clutch problem?
x-isle
After a long Motorway drive this morning, got to a roundabout put the clutch in, changed gear fine........clutch pedal stuck to the floor. Give it a bit of a kick and it came back up.
Now it just sticks everytime you put the pedal to the floor. If you push the pedal 2/3 of the way in it's a bit lethargic returning but comes up.
Gear changes are fine, all drives fine, just the pedal sticks in. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #85421 20th Aug 2011 11:31pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
I am thinking that it could be due to the hydraulics in the clutch, it reminds me of this http://www.mudstuff.co.uk/Meck_Lock.shtml which gives a dead clutch by cutting the hydraulic pressure.
HTH
Jack
Post #85422 21st Aug 2011 12:30am
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
I had some problems with the hydraulics a month ago - as I still have the original clutch I was certain it was that causing the problem - but it was the hydraulics. The clutch stayed down a few times and the point where there clutch engage changed a lot Shocked I was able to "pump" the pedal as you do when air is in the system - did it a few times over 3 days - that is about a month ago and everything has been fine since Question I checked fluid - nothing unusual.
Regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #85426 21st Aug 2011 6:45am
x-isle
Thanks for the replies, I'll take a look.
The strange this is though, the pressure in the system is all ok. The clutch operates fine when you depress it and disenages ok, it's just it doesn't return. I'll take a look a the pedal pivot just in case it's just jamming, but I can't see it being that. Craig Rogers
2007 Puma 110 XS
Post #85427 21st Aug 2011 7:09am
CRJ
Just thought of an old series II I once had - where the clutch had similar problems - that was the "arm" in the master cylinder that had bended a bit - causing it to get slightly stuck when depressing the clutch. That was of course on a series II but the cylinder looks about the same....
Regards
Puma 130 - 08- sold
110 CC 2003
Post #85428 21st Aug 2011 7:29am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Could be you've got a spring out of the clutch plate which is interfering with the clutch, happened to alot of people. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #85434 21st Aug 2011 7:46am
x-isle
Before I went up to the Peaks today (loads of waves to loads of others today!), I sprayed the pedal pivot and spring with penetration spray.
...........So far it's all ok again..... Could be lucky and it is just the pivot point on the pedal. Craig Rogers
2007 Puma 110 XS
Post #85484 21st Aug 2011 6:15pm
willy eckerslike
Hope so Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #85485 21st Aug 2011 6:42pm
Happyoldgit
Sounds like potential master or slave cylinder seals on the way out. However my clutch pedal went floppy the other week, turned out to be the spring had popped out of it's location on the pedal itself. Steve.
http://forums.lr4x4.com
Post #85488 21st Aug 2011 7:11pm
x-isle
The pedal and hydraulics all feel fine, there's was a definate sticky feeling with the actual pedal.
Fingers crossed all fixed, did about 120miles today with it all fine. Craig Rogers
2007 Puma 110 XS
Post #85495 21st Aug 2011 8:45pm
x-isle
Just thought I'd update you on this.......
It's been quite a few weeks now and the only thing I did was spray the pedal with Muc-Off bike spray which is similar to penetration oil.
So far it's been fine and the pedal is a lot easier to push too. I think that the pedal was just a bit gunked up and sticky.
PHEW! Laughing Craig Rogers
2007 Puma 110 XS
Post #88840 13th Sep 2011 10:38am
