![]() | Home > General & Technical (L663) > load cover |
You are joking
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 199 ![]() ![]() |
Why?
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
It won’t even attach as it slots into special mouldings in the rear Door frame and hooks onto two special hooks near the C pillar but just to re-assure you I’ll get mine out and rake some photos and measure it. It’s just a thin mesh and very sensible and easy to stow when not in use. The car is also a whole lot wider than the previous 110. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Ok here you are
Rigged in position ![]() It attached to the door frame like this ![]() And to the window surround in the boot like this ![]() ![]() All de-rigged ready for stowage - either in the tailgate pocket or in the black hole under the boot floor ![]() Here in the tailgate ![]() Here with the dimensions written on the photo - the one I forgot to edit in is the widest one which is 130cm across the backs of the rear seats ![]() Here are the eyes that hook onto the clips on the window surround ![]() Here’s how it hooks into the trim on the door frame ![]() 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Oops double post Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Perfect thank you. That’s super helpful
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I can't believe you drew on it! I hope it's washable ink. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Technically it’s Apple Inc....it can be removed using the undo button!
