Home > General & Technical (L663) > load cover |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
You are joking 130's have feeling's as well you know
26th Aug 2020 4:39pm |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 189 |
Why?
26th Aug 2020 4:53pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
It won’t even attach as it slots into special mouldings in the rear Door frame and hooks onto two special hooks near the C pillar but just to re-assure you I’ll get mine out and rake some photos and measure it. It’s just a thin mesh and very sensible and easy to stow when not in use. The car is also a whole lot wider than the previous 110. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
26th Aug 2020 7:15pm |
Ok here you are
Rigged in position It attached to the door frame like this And to the window surround in the boot like this All de-rigged ready for stowage - either in the tailgate pocket or in the black hole under the boot floor Here in the tailgate Here with the dimensions written on the photo - the one I forgot to edit in is the widest one which is 130cm across the backs of the rear seats Here are the eyes that hook onto the clips on the window surround Here’s how it hooks into the trim on the door frame Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
26th Aug 2020 7:46pm |
Oops double post Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
26th Aug 2020 7:48pm |
Perfect thank you. That’s super helpful
26th Aug 2020 7:54pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I can't believe you drew on it! I hope it's washable ink. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
4th Sep 2020 3:17pm |
Technically it’s Apple Inc....it can be removed using the undo button! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
4th Sep 2020 3:55pm |
