Home > My Defender > G4 Edition 90 |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7904 |
Acquire parts...? James
26th Jul 2020 7:14am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
Speed parts. (Or is that ‘less-slow’ parts).
26th Jul 2020 7:45am |
Like a turbo... or LS3? James
26th Jul 2020 9:40am |
Oh believe me, I have enough ear ache over the LS route....
26th Jul 2020 10:37am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10733 |
Keeper. Clayton. |
27th Jul 2020 7:34pm |
I’ve been acquiring bits, ready for a week of spannering...
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
12th Aug 2020 5:58am |
Nice bits there GREENI, but what is different with the TB 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
13th Aug 2020 8:04pm |
Hey up Clayton, it’s a Disco t/box, so increases the gearing, making dual carriageway cruising a lot more comfortable.
13th Aug 2020 8:25pm |
Thanks GREENI, thought it maybe, but still had to check 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
13th Aug 2020 8:52pm |
A few days of spannerng. Having removed the intercooler to replace it with a BAS jobby, i found my rad was a bit worse for wear, though not leaking, there was a large amount of corrosion so a call to a friend who just started a motor factors company, he delivered one in person, same day, on a Saturday!
Click image to enlarge However i dropped the t/box out and replaced it with a 1.2 disco version. Click image to enlarge It’s also had a few other bits n bobs and is now waiting for replacement tyres. The bushes still need doing, but it now drives better with cruising speed achieved at lower revs = quieter. Click image to enlarge Looking forward to using it on lanes over autumn/winter. Last edited by GREENI on 2nd Sep 2020 9:20am. Edited 1 time in total |
31st Aug 2020 7:55pm |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1972 |
Good work. I much prefer my 90 since the disco transfer box was fitted.
31st Aug 2020 8:00pm |
G-P Member Since: 27 Oct 2019 Location: Cambridge Posts: 16 |
I am planning on getting 1.2 gears next on my TD5, is it best to get a whole box from a disco or put the replacement gears in from Ashcroft? Mine has only done 53k and most Disco’s seem to have done 100k + so little worried about putting in a tired box. Thanks
31st Aug 2020 9:07pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Out of interest, how did you sort the speedo drive out? D2 takes speedo from one of the wheels vs Defender using t/box.
Saw a yellow G4 90 heading south on the M3 at Winchester on 22 August, first time I've actually seen one that colour in the flesh! |
1st Sep 2020 6:54am |
The speedo drive was from the rear output nose (not sure it was a d2 box now..a mate had it for his Wolf 110 but know he's putting in an LS, so it came £free), though a very different 2 pin plug on the box, compared to a 3 pin connector on the 90.., I pulled the plug off the t/box and installed the original one off my 90, though the plastic green square drive was too big for the box's gear...a date with a file sorted that out! It works fine.
At G-P, I'm sure Ashcroft may be able to either supply you with the gears to swap on your own box, or you could send your box to them and ask for the same box back.. Dave is on this forum as 'Ashtrans', best to word him up. |
1st Sep 2020 9:42am |
