Home > For Sale & Wanted > [SOLD] Provent 200
[SOLD] Provent 200
I bought this for my 110 but have painted myself into a corner with regards space to fit it, so I'll need a different cunning plan.
Brand new, complete with 19mm adapters to fit the standard LR pipework:
This lot cost me over £120 but am offering it for £80 plus postage, if required. I haven't priced it up but I expect that to be in the region of £6-7.
Can be collected from Deepcut, Surrey, or posted at cost.
Thanks for looking. Darren
Post #853248 30th Aug 2020 10:35pm
grafty99
Yes please, Darren Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #853251 30th Aug 2020 10:41pm
Bluest
Slim chance, but 2nd dibs if it doesn’t go Thumbs Up 2007 110 TDCi Station Wagon XS
Post #853254 30th Aug 2020 10:47pm
hank
Provent 100 fits... Just!
 > 110 XS Double Cab
Post #853399 31st Aug 2020 6:27pm
Mo Murphy
You have a cup holder in your engine bay, that's useful ! Wink
50 Shades of Pennine Grey
Post #853417 31st Aug 2020 8:20pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Rolling with laughter Rolling with laughter Rolling with laughter Rgds.
Chris
Post #853418 31st Aug 2020 8:24pm
hank
Mo
Mine never had the cover fitted Crying or Very sad must get that sorted > 110 XS Double Cab
Post #853424 31st Aug 2020 8:48pm
Yeah, I was looking at those. My only concern is that whilst it's just big enough for the engine in standard trim, it's not if remapped to 150 or 170bhp, which is something that I'm considering. I need to do a bit of measuring but I'm hoping that the Provent 150 will be the good compromise between size and capacity. Darren
Post #853441 31st Aug 2020 9:16pm
hank
Indeed. For reference the provent 100 seems to be be performing ok on mine which is remapped to around 165bhp > 110 XS Double Cab
Post #853442 31st Aug 2020 9:25pm
I guess the consequence of a smaller unit will be that the filter clogs sooner. As long as you're aware though, that's probably not the end of the world. Darren
Post #853449 31st Aug 2020 9:36pm
Pacha
TBH, I spent ages looking into this and it is a bit like chasing shadows.
The stuff on eBay is pretty good for a much reduced cost - decent ones have the correct filter and overpressure diaphragm.
Using this in a Defender is dead simple - the inlet and outlet need some creativity due to the diameters of hoses etc.I used plastic reducers and reinforced hoses. If you think about it, it is replacing a hose that goes straight to the airbox!
The vent tube needs an on off valve - beyond this there is no complication. I have yet to see anybody say that their airbox/filter has major oil contamination before using a Provent. Rgds.
Chris
Post #853483 31st Aug 2020 11:17pm
Ah, the filter I was referring to was the one inside the Provent. If choosing too small a capacity causes that filter to clog quicker than expected then there may be unintended consequences.
As for the eBay copies, not this time, thanks. Unsealed 4x4 in Aus did a comparative test on a range of different filters and the cheaper copies didn't fare well.
https://www.unsealed4x4.com.au/the-great-o...omparison/ Darren
Post #853521 1st Sep 2020 8:45am
hank
The airbox and air filter would not show contamination because the recirculation pipe is plumbed in downstream.
If you take the intake pipe off the turbo inlet elbow you will see the oil contamination/gunk > 110 XS Double Cab
Post #853527 1st Sep 2020 9:01am
Pacha
Read that (and a few Youtube reviews) etc. before I made the purchase. Initial thoughts are there is little difference between the better copies and the original.
Will (obviously) be keeping a close eye on what this actually does etc. and will feed back. Rgds.
Chris
Post #853530 1st Sep 2020 9:07am
^^^ All I can say to that is that I must have read a completely different set of reviews! Rolling with laughter
I suspect that any form of catch-can or filter makes a big difference. The difference between a top-class one such as the Provent and a knock-off may be less significant.
The Provent certainly does seem to help keep the MAP sensor a lot cleaner than before.
Post #853544 1st Sep 2020 10:42am
