Home > Tdi > windows misting |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1115 |
i put my heater on for the first time in a while and the screen / side windows misted up and a odd smell started then the engine temp went up , anyone got a idea whats going on
27th Aug 2020 8:28pm |
thanks bear for the fast reply
27th Aug 2020 8:31pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20546 |
Check your intake water ‘duck bill’ valves, there are three they are often clogged up and wet and will draw in wet air and cause this too. Take them out if they aren’t already, clean and replace. KEEP CALM AND Drill ON
27th Aug 2020 8:54pm |
thanks steve where abouts are they
28th Aug 2020 5:19pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 930 |
This! Once they are blocked it turns the interior into a steamy sauna! |
28th Aug 2020 5:37pm |
Thanks just what I'd happening
28th Aug 2020 5:41pm |
Locate the fan air intake, open bonnet and follow ducting. Feel underneath and you’ll feel the first one, then the other two are a bit further down just before the foam seal into the fan assembly.
Worth checking the gap there too, the foam should be a nice seal between the two but often there is a gap. Mine had this, can cause leaks and draw in warm engine air. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
28th Aug 2020 8:00pm |
Not sure if we talking about the same thing, I had a blocked drain in the wing air intake duct, so took off grill, scooped the muck out, and poked my finger through the drain at the bottom, it has a rubber grommet type thing that discharges under the wing. Its something you need to keep a check on yearly, more so if you park under trees.
28th Aug 2020 8:24pm |
Yes, same part. KEEP CALM AND Drill ON
28th Aug 2020 9:02pm |
28th Aug 2020 9:07pm |
