![]() | Home > Maintenance & Modifications > Bilstein shocks on a 90 |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3707 ![]() ![]() ![]() |
What are you looking for? I’ve had Bilstien, OEM and fox. In terms of smoothness of ride, that order would be from stiffest to soft, so bilstien for speed, fox for comfort.
DOOFER Member Since: 07 Oct 2012 Location: Suffolk Posts: 412 ![]() |
I was hoping the bilsteins would be smoother than oem. Out of interest are you running standard springs? DON'T PANIC
Nope. Alive comfort springs. If you were nearer you could come and have a go!
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2058 ![]() ![]() |
I had the the Bilsteins and found them a bit harsh so I went back to standard shocks and springs and added some spring isolators.
so maybe standard shocks and comfort springs are the answer!! DON'T PANIC |
Yes Doofer. Alive comfort springs are a game changer... adding Bilsteins is a step backwards, standard dampers are better, but have a limited life...they’re cheap for a reason. Add Fox and the ride is sublime. My v8 is soooo comfy with Alive and FOX.
Do you have standard fox shocks or the remote reservoir jobbies? DON'T PANIC
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20746 ![]() ![]() |
Any pics of the Fox ones at all?
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 285 ![]() ![]() |
Running factory springs with fox shocks. Very happy with the result. Previously had Bilsteins but found ride too harsh.
FOX 2.0 none remote.
Same. 2.0 no remote.
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
Have Alive Comfort set up with Bilsteins on ours. Huge improvement over originals.
More than pleased. ![]() 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
Maverick XS Member Since: 07 Apr 2020 Location: London Posts: 13 ![]() ![]() |
My truck came with standard springs and shocks. I found the ride unacceptable, so I changed for Alive lowered springs and Bilsteins'. This was a big improvement, but still a little harsh for me. So I changed the shocks for Fox adjustable with the reservoir. It has totally transformed the truck. It's definitely worth the money, the ride and handling is now amazing!
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
TD5Neil Member Since: 02 Nov 2017 Location: Cambridgeshire Posts: 42 ![]() ![]() |
Standard springs and Bilsteins for me. Ride is a lot firmer than the old standard shocks but feels so much more planted. Not too harsh when I had a day green laning but if off road a lot it will probably get too you. I’m mainly road use. 90 TD5.
