Home > Technical > Puma door glass removal
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Hi Folk,
How the bloody hell do you remove the glass from the drivers and passengers door Big Cry Big Cry
Shane
Post #852312 27th Aug 2020 9:28am
ibexman
It’s quite easy it’s only door card nuts bolts and screws
Post #852314 27th Aug 2020 9:38am
shanecl
yep got that far, have you taken one out yourself
Post #852317 27th Aug 2020 9:40am
dorsetsmith
with the door card removed
have the top window glass one inch up from top rubber seal so you that you hold it in place with clamp or tape and stop it from dropping down
window winder to window fixing screws loosened so that sliding can be made free from the bottom of the window glass next
remover window winder inner panel fixing screws and with the two window winder to window fixing screws loosened so you remover winder inner panel also disconnect and remover inner door lock opening lever
with the window winder inner panel removed you can now remover the glass, at the bottom the hing end window channel you find self tipping screw remover it with now the tricky bit you will need to hold the window at the bottom end with the clamp or tape removed from the top you can work window out from the door frame
Post #852324 27th Aug 2020 9:59am
Edit - post deleted because the one above, which it crossed with, says it so much better.
Post #852325 27th Aug 2020 10:00am
dorsetsmith
Yes
removed from old door and fitted in to new drivers door
Post #852342 27th Aug 2020 11:09am
shanecl
Thanks @dorsetsmith, i was being gently trying to twist the glass but will try again moving in the direction in the photo Smile
Post #852344 27th Aug 2020 11:11am
shanecl
Thanks blackwolf
Post #852345 27th Aug 2020 11:11am
Polarismd
Images?
Hi,
Is there any chance someone could add the images back into this post?
Thanks in advance.
Chris
Post #975109 19th Dec 2022 10:40am
