Home > Td5 > Central locking barrel
Greeny
Evening. The drivers door lock barrel has decided to seize and after taking it out, it is completely ruined.
I know you can get a replacement barrel cheaply, but my question is, can I get a barrel made up to match my current key?
I don't want an additional key for one door, I want it to be the same for all doors and my ignition. If anyone has had this issue and knows a resolution then please let me know.
Cheers Greeny. Instagram - @Land_Rover_Defender
Post #851761 24th Aug 2020 5:48pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Behind the dash binnacle there should be a paper tag tied on to your ignition key barrel. With that number you can get what you need from JLR (supposedly) Neutral 🤷‍♂️
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #851928 25th Aug 2020 1:41pm
The key number is also sometime recorded on a tag attached to the keyfob, but if the vehicle was preowned it probably isn't there any more. A good automotive locksmith (if you can find one) should be able to re-tumbler the lock to suit a particular key, this isn't difficult but you need access to supply of tumblers.
Post #851974 25th Aug 2020 6:14pm
