Home > Technical > Battery light on. Any funnies and how to change? |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5874 |
Alternator swapping time. 1999 Defender TD5 110
21st Aug 2020 10:17am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20580 |
Yes, Alternator voltage isn’t performing by the looks of those voltages.
Mine stays at 14.6v running, pretty much consistently. I think it’s one of those things that like Blackwolf I think mentioned is typical of Defenders and likes to come and go making it difficult to pinpoint. I’m pretty sure that the Alternator there is knackered and it’s been intermittent as it’s been on it’s way out. Definitely swap it or it will let you down, if it wasn’t for the fact the west hung is warm the first cold weather we would have you’d be let down. As it is, it could leave you stranded unless you have backup batteries and even then it won’t be charging both properly. Bit of a pain I know, these things just happen unfortunately. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
21st Aug 2020 3:27pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8152 |
changed the alternator.
Charges around 14.1, 14.2 after initial start then 30mins later around 13.7. I am assuming once battery charged it drops the rate? If load applied it momentarily drops 0.1v, heated front screen, then comes back up to where it was but still only 13.7. Not had any repeat battery lights on and not had a no charge scenario repeat. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Aug 2020 7:47am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 733 |
Might be worth trying another multi meter, just in case the one you have is reading low.
22nd Aug 2020 11:13am |
