Home > Technical > Battery light on. Any funnies and how to change?
Page 2 of 2 <12
jst
Drove it back this morning after a windy night camping on the hill!
13.6v at batteries rising to 13.8 after an hours drive engine running. Battery had 12.5 in one and 12.6 in the other (VSR joining them) at start of trip.
when i ran it static in the field Wed it was 14.2v.
so now dropped to 13.6v
i am thinking change alternator anyway. - thoughts? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #851256 21st Aug 2020 9:30am
excossack
Alternator swapping time. Sad 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #851261 21st Aug 2020 10:17am
Yes, Alternator voltage isn’t performing by the looks of those voltages.
Mine stays at 14.6v running, pretty much consistently.
I think it’s one of those things that like Blackwolf I think mentioned is typical of Defenders and likes to come and go making it difficult to pinpoint.
I’m pretty sure that the Alternator there is knackered and it’s been intermittent as it’s been on it’s way out.
Definitely swap it or it will let you down, if it wasn’t for the fact the west hung is warm the first cold weather we would have you’d be let down.
As it is, it could leave you stranded unless you have backup batteries and even then it won’t be charging both properly.
Bit of a pain I know, these things just happen unfortunately. TheThunder Rolls🇬🇧🇺🇸
Post #851300 21st Aug 2020 3:27pm
jst
changed the alternator.
Charges around 14.1, 14.2 after initial start then 30mins later around 13.7. I am assuming once battery charged it drops the rate? If load applied it momentarily drops 0.1v, heated front screen, then comes back up to where it was but still only 13.7.
Not had any repeat battery lights on and not had a no charge scenario repeat. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #851376 22nd Aug 2020 7:47am
Balvaig
Might be worth trying another multi meter, just in case the one you have is reading low.
Post #851411 22nd Aug 2020 11:13am
Page 2 of 2 <12
