![]() | Home > Technical > puma speedo pairing |
dazzling1611 Member Since: 08 Jun 2020 Location: morpeth Posts: 35 ![]() ![]() ![]() |
some of you guys must know about this.
im trying to sort my indicator fault out and ive narrowed it down to the dash clocks , but need to know if i fit new clocks with the plug and play or do they need mating up to the ECU for the rev / speedo and everything else to work correctly. |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
2.4 is a case of just plugging it in, and it works fine, but it retains the odometer history of the vehicle it came from. Sorry don't know about the 2.2, but I am sure someone more knowledgeable will be along soon .
thanks for the info, i thought you must be able to plug and play these clocks and then pair with the ecu for the mileage
