Home > In Car Electronics > DAB Signal. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5864 |
Did you get anywhere with this Steve?
I get some interference from USB charges, both cheap Ebay ones and Bluesea versions but only when leads are connected and charging devices. Used to wipe out FM signals. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
30th Sep 2020 8:25am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20484 |
Not as of yet, I haven’t got around to it really - being very busy with work.
I do know I get some whine from speakers with LED light bars on so that one culprit that is commonly known. LED headlights can be another too, as well as USB chargers and various other gubbins. Ideally you want everything isolated except DAB system, with good DAB signal then power up each circuit to see if any are suspect with signal loss. (That isn’t always easy though and is an idealistic approach compared to parking locations etc). You’ve actually reminded me to look into this again which is a good thing. I would try inline fettrite clips like TDK’s, on both the supply and charger lead. See what happens. I do wonder if the phone signals have an affect too. When I get the chance I’ll investigate further, at least with Ferrite clips first. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
30th Sep 2020 4:45pm |
Just purchased some snapon ferrites. Will add some to either end of the DAB aerial lead and go from there. 1999 Defender TD5 110
9th Oct 2020 10:50am |
