Home > My Defender > here she is |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10844 |
Fingers crossed for you Clayton.
17th Jul 2020 8:11pm |
The first pic says it all Clayton.
31st Jul 2020 7:53pm |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 |
Well she failed , nothing major except for rubber boots , so getting 3 new ball joints fitted and off we go again , mind you , she’s only done 270mile since last time , so glad nothing nasty appeared
Click image to enlarge |
10th Aug 2020 2:35pm |
3 new ball joints fitted and headlight adjusted , and she’s all ready for another year , the first local pit day is on Sunday 24th August , unless we get any rain , I doubt I’ll go , the pit will be like concrete and it be to uncomfortable for me , must be an age thing
12th Aug 2020 2:56pm |
Hello everyone , went for a blast with no roof on , and had already noticed my super snorkel which weighs a lot was collapsing my bulkhead , to the point where the door would not shut , so removed the windscreen and the bracket has rotted away , I’ve cut it all out and will build a little bracket to prevent it happening again , although I’ll not run the snorkel now unless I crossing the lake
13th Aug 2020 6:05pm |
Better late than never, nice to get it sorted Clayton.
13th Aug 2020 8:13pm |
All done bar the drilling , new bolts n bits on the way , super solid now
14th Aug 2020 1:18pm |
Whilst I wait for my windscreen to bulk head foam to appear , I thought I’d test fit the screen for strength ,it’s so solid and zero movement , I’ve now permanently ditched the 3” home made snorkel-ish and I’ve got some reinforced hose coming , I can slide this on for lake crossing and off for the rest , gave the screen a dam good clean too , lovely
Click image to enlarge Click image to enlarge Click image to enlarge |
15th Aug 2020 7:15pm |
Hello everyone , have re-jigged my tub stuff to allow for quicker and easier use
17th Aug 2020 6:00pm |
Looking good with the repair now it's all back together Clayton.
18th Aug 2020 8:34pm |
Cheers dude Hope you are well ? I’ve fitted the new foam between the screen n bulkhead and fitted the screen properly . I’ve got the air intake at the side of the front wing again as factory for the forthcoming pit visit , yep I’m going Sunday . I’ll sort the snorkel another day ( I must not cross the lake ) I’ll bung with wing hole up with some tape
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
19th Aug 2020 5:40pm |
I'm all okay thanks and it looks much better with the foam in place
Had to laugh a bit as you put about not going in the lake, i bet you do Have a good time at t'pit Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
21st Aug 2020 8:00pm |
Cheers fella I have now installed a temp snorkel , 3” reinforced hose and breathers pipe just incase she goes thru the lake , all easily removed for non pit runs , lovely jubbly
22nd Aug 2020 1:52pm |
A brilliant morning at the pit , the lake is now a puddle, it’s got to be down by 2ft , but was still great fun , recent rain made it soft enough for the special tracks to work there magic . As usual there was several raised trucks with hugs tyres and huge lifts , but they always seem to break really easily , anyways my tub has moved so tomorrow she gets cleaned and tub adjusted as I got the day off , more pics as they appear
23rd Aug 2020 12:53pm |
