Home > Td5 > Options to replace a TD5 turbo? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6113 |
Disco ones are the same as defender (although i'm not sure if the boost pressure is exactly the same, as the disco is 136bhp and the defender 122, so your ECU may freak out if you just bolt it straight on.... check the pressure first or get one of the ECU boost boxes)
a good second hand one should work, but you should try and check the milage first... it moght have 200,000 on it! I've got an IRB VGT turbo on my 110 (Td5), with a 190bhp ECU file, it flies, and pulls very well from low revs.Even before i got it flashed up to 190, i was running a 140bhp tune with the VGT, and it still pulled away much better than standard... more like a "modern" car does, seemless power as opposed to on/off when you reach the on boost point. |
18th Aug 2011 5:51pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
i will be going VNT turbo on my new ride
well worth the money. |
18th Aug 2011 7:07pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Gary at Alive is just about to start selling a VNT turbo with all the right pipes to fit and everything, from what i gather its a "made to measure" thing rather than a "make the turbo fit the engine" thing.
18th Aug 2011 8:49pm |
The IRB/Bell ones just bolts in place too. I've got one of the early ones, and had to change the oil feed pipe, but that's all.
Later ones drop straight in. |
18th Aug 2011 8:51pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 |
Ive got a recent Stage 2 from Irb just had to change the oi feed pipe very pleased
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
19th Aug 2011 5:09pm |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 |
Where the standard sized turbo (standard, hybrid, or the TT vgt) fall short, our new conversion really excells! It's been almost 2 years in development to get to where we are now. Testing has been taking place on a very heavy working Defender, A Defender 90 hill rally car, and on our own Discovery Td5 mule. To date, all is going to plan perfectly, without a single failure so far. Come and see us at Peterborough. It should hopefully be ready for then, and fitted to our Black Td5 90. |
20th Aug 2011 10:24pm |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 |
Go for a IRB VNT if you can afford it, you won't be dissapointed it's the best thing I did.
22nd Sep 2011 7:20pm |
