Home > Td5 > Options to replace a TD5 turbo?
Mark_110DCPU
United Kingdom 2001 Defender 110 Td5 DCPU Chawton White
I noticed on our recent jaunt to Wales that my turbo is really very noisy on my 156k mile old TD5....
This leads me to believe that it is not very happy, and I would rather have thought about, and possibly acted upon this before it becomes an immediate issue.
So, having never replaced a turbo I wondered what options were out there...
Replace with new or recon unit?
replace with secondhand unit?
uprate turbo with something a bit more fun - maybe something with a variable geometry?
Anyone have any direct experience?
Are Disco TD5 turbos the same as defender ones?
Mark [:O|===|O:] 2001 110 TD5 Doublecab
Post #85068 18th Aug 2011 5:29pm
Disco ones are the same as defender (although i'm not sure if the boost pressure is exactly the same, as the disco is 136bhp and the defender 122, so your ECU may freak out if you just bolt it straight on.... check the pressure first or get one of the ECU boost boxes)
a good second hand one should work, but you should try and check the milage first... it moght have 200,000 on it!
I've got an IRB VGT turbo on my 110 (Td5), with a 190bhp ECU file, it flies, and pulls very well from low revs.Even before i got it flashed up to 190, i was running a 140bhp tune with the VGT, and it still pulled away much better than standard... more like a "modern" car does, seemless power as opposed to on/off when you reach the on boost point.
Post #85074 18th Aug 2011 5:51pm
T1G UP
i will be going VNT turbo on my new ride
well worth the money.
Post #85082 18th Aug 2011 7:07pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Gary at Alive is just about to start selling a VNT turbo with all the right pipes to fit and everything, from what i gather its a "made to measure" thing rather than a "make the turbo fit the engine" thing.
Post #85106 18th Aug 2011 8:49pm
The IRB/Bell ones just bolts in place too. I've got one of the early ones, and had to change the oil feed pipe, but that's all.
Later ones drop straight in.
Post #85107 18th Aug 2011 8:51pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Ive got a recent Stage 2 from Irb just had to change the oi feed pipe very pleased
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #85247 19th Aug 2011 5:09pm
Alive Tuning
Where the standard sized turbo (standard, hybrid, or the TT vgt) fall short, our new conversion really excells! Mr. Green
It's been almost 2 years in development to get to where we are now. Testing has been taking place on a very heavy working Defender, A Defender 90 hill rally car, and on our own Discovery Td5 mule. To date, all is going to plan perfectly, without a single failure so far.
Come and see us at Peterborough. It should hopefully be ready for then, and fitted to our Black Td5 90.
Post #85419 20th Aug 2011 10:24pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Go for a IRB VNT if you can afford it, you won't be dissapointed it's the best thing I did. Thumbs Up
Post #90653 22nd Sep 2011 7:20pm
