Home > Technical > Quick PUMA maintenance question |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 300 |
I think your meant to replace both every 5 years.
11th Aug 2020 9:14pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Every 2 years. Rgds. Chris |
11th Aug 2020 10:44pm |
CharlieDonuts Member Since: 16 Jun 2019 Location: Illiers Combray Posts: 133 |
Thank you for this. I couldn't seem to find this information anywhere.
12th Aug 2020 4:43am |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1631 |
every 2 years is recommended
a lot of modern cars used to be at 3yrs, soit was out of warranty period but almost all the ones we have at work are 2 years now. |
12th Aug 2020 6:39am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3469 |
Would atmospheric conditions play a part? Dot3/4 absorbs water. In low humidity areas, I would guess need less changes than the high humidity areas. Is the vehicle parked outside with lots of dew overnight? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
12th Aug 2020 7:31am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1083 |
Clutch fluid every 2 years, too? |
12th Aug 2020 9:37am |
I do - not a big job TBH. Rgds.
Chris |
12th Aug 2020 9:47am |
I had the same discussion with the Indy that looks after the 110 last October after he changed the fluids, the Land rover service sheet had every five years or a certain mileage but he said as the fluid starts to break down as soon as the the container is opened he tests the fluid on every service he does . He now recommends every two years . Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
12th Aug 2020 10:20am |
For clutch fluid the sheet just says "check/top up" every year / 12k miles (every 2 years for brake fluid).
But if changing it is an easy job, I'll put it on the list |
12th Aug 2020 10:47am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8152 |
i do mine every 2 years or 12k Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
12th Aug 2020 1:03pm |
