Home > Technical > 2.4 revving after some gear changes
jst
just after a few suggestions on what to check please.
2010 2.4 puma, 65k.
Occasionally after a gear change, only happened when slowing so far, clutch pedal pressed down and engine revs increase and keep increasing until acc pedal is blipped, cluch is still pressed down. Goes to 3k plus if you leave it, I blipped acc to stop it at that engine speed.
Its never done it changing up and has only done it a few times after (6 maybe) after completing an hours driving in last 1k mile.
If its pedal box end why does it only doing it changing down?
Could it be part of the antitrust gone wrong. Ie clutch in ecu increases revs a bit but its increasing them too much.
Don't have a code reader to hand, could possibly borrow one to check for codes. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #848163 5th Aug 2020 8:55am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Touch wood never had on the 110 but had similar experience when driving a works transit, reported problem and garage said it was a problem with the anti stall system not recognising clutch was depressed. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #848169 5th Aug 2020 9:20am
Lwb97
Wales 2002 Defender 90 Td5 HT Oslo Blue
More than likely itโ€™s the clutch switch. Iโ€™d bypass it and see if your problem goes away.
Post #848194 5th Aug 2020 12:15pm
jst
cheers, thats all sounds possible.
if i recall from reading earlier threads the switch has to be bypassed closed if the plug is removed?
if it was the switch how come touching the accelerator stops it? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #848208 5th Aug 2020 1:34pm
rallysteve
Yes bypassing the clutch switch on a TD5 = disconnect the plug and leave, on a TDCi = disconnect the plug and connect the wires.
AFAIK the anti-stall is only active whilst the accelerator pedal is not pressed. This is certainly the case with the TD5 and can be demonstrated if manoeuvring on a steep slope, gentle use of clutch with no throttle doesnt result in a stall but resting your foot on the throttle whilst doing the same manoeuvre results in a stall.
Post #848210 5th Aug 2020 1:53pm
rallysteve wrote:
... the anti-stall is only active whilst the accelerator pedal is not pressed ...
Correct, blipping the throttle will "disengage" AS. It might also be worth checking that your brake lights are working (failure of these, or the fuse for them, has strange effects on the ECU) although in this case I don't think this will be the problem.
Post #848274 5th Aug 2020 7:41pm
jst
Ok, cheers on all. Will bypass clutch switch and see it that works. Brake lights are good. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #848287 5th Aug 2020 8:34pm
It does sound like the clutch switch.
The connectors are Junior Power Timer 2 pole. ๐Ÿ‘๐Ÿป KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #848296 5th Aug 2020 9:25pm
jst
Cheers Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #848344 6th Aug 2020 9:39am
jst
bypassed the switch. still does it.
was thinking on this. Anti stall is complemented by accelerator input on a TDCI. ie it works with it and uses which ever is greater anti stall input or pedal input. Td5 anti stall turns off as soon as you touch accelerator.
anyway, closed the loop bypassed it with proper fittings and it still does it.
does it in fact when driving sometimes, come off the gas and it still puts power down a little until throttle touched again.
just move evident when changing gear if immediately after touching accelerator pedal.
connector on pedal looks good.
i am deducing its a pedal fault that clears when pedal is touched again. anyone any ideas or come across it before? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849382 11th Aug 2020 8:51pm
Zed
Potentiometer acting up? WARNING.
Post #849389 11th Aug 2020 9:47pm
I know the VCV being often mentioned as a cure all scenario but when was yours last changed?
I have had the issues youโ€™ve mentioned before, and the culprits were mainly the clutch switch or VCV.
The MAF & MAP Sensors, is unknown but I replaced mine for new but they may be worth cleaning and checking.
Is your EGR active too or is it deleted?
If active that can again be a culprit but a DTC is usually present with most of the factors except the VCV.
If nothing else, these maybe some ideas to try. KEEP CALM AND Drill ON
Post #849396 11th Aug 2020 11:03pm
jst
i was thinking pedal potentiometer too. but havent read much on these going.
VCV - thats a thought, another easy to change and hadnt considered that.
EGR - deleted. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849439 12th Aug 2020 7:37am
As far as I know the anti-stall on a TDCi is completely inactive if there is any pedal input, and only works with zero pedal input.
Changing the pedal is relatively cheap and easy and would rule it out (or rule it in).
Post #849454 12th Aug 2020 9:15am
jst
You can accelerate above anti stall rpm it just doesn't react to inputs below it or turn it off like it did with td5 era. Certainly the case on early puma when they came out. It was a point raised to lr for sorting from td5 era back from my days working with jlr. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849457 12th Aug 2020 9:21am
