Home > Technical > 2.4 revving after some gear changes
Page 2 of 2 <12
jst
May swap pedal with another vehicle and see if that cures it, pedals don't seem to be cheap! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849459 12th Aug 2020 9:21am
On my 2007 Puma, if you touch the accelerator pedal the AS is immediately rendered inoperative.
If, for example, you start climbing a hill on tickover (foot off the accelerator pedal), the AS will fuel the engine to ensure that the required torque is available to prevent the engine from stalling and maintain tickover revs, exactly as it should.
If you then touch the pedal and make a very small pedal input, not enough to increase the engine speed significantly, the engine will stall as a result of the AS fuelling stopping. If you make a decisive pedal input, sufficient to drive away, the off it will go.
The AS will not increase engine speed, just torque. If the hill is too steep to climb on tickover no matter how the engine is fuelled, the engine will stall.
Idle Jack will increase engine speed, but is a wholly different thing.
Post #849472 12th Aug 2020 10:32am
jst
i need to do a quote Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849495 12th Aug 2020 12:09pm
jst
yep agreed
blackwolf wrote:
If you then touch the pedal and make a very small pedal input, not enough to increase the engine speed significantly, the engine will stall...
err i disagree. i have just been out and tried it now in 3 pumas just to make sure i wasnt going mad. in low range up a hill, 1st (idel jack) 2nd and 3rd. so an applied load(hill), anti stall keeps vehicle moving at same pace, gentle press of accelerator and nothing changes, vehicle continues to move at same pace.
Keep accelerating and when you input more fuel than the vehicle is receiving from AS engine speed increases as does pace.
immediately come off the accelerator and still with hill load applied vehicle continues to climb at original AS pace.
correct as above so it doesnt turn it off like a td5.
on a hill with td5 antistall (which is nowhere near as good) as soon as you touch the accelerator it defaults to tickover rpm fuelling and will stall unless accelerator is pretty much floored.
i distinctively remember the presentation on AS at the time being different to the td5 as it works with human input.
we may be splitting hairs here on terminology but for user you can accelerate through from light to heavy accelerator input and it doesnt stall on my 3 currently here, or the previous ones i have had or any of the LRE ones we instructed with.
either way, i still get increase in engine revs when its not required. does it sometimes clutch in, sometimes clutch out. never done it on a cold engine and appears to do it after a light throttle application. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849501 12th Aug 2020 12:19pm
Interesting, I'll have a play when I next get the opportunity. I wonder if LR and HR behave differently, ie AS alone as opposed to AS and IJ.
Post #849509 12th Aug 2020 12:40pm
jst
i dont know on that. Idle Jack certainly working as it should be, and as you say a totally different function to AS. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849516 12th Aug 2020 1:02pm
jst
brake light switch is also something to look at apparently.
brake lights work.
but just trying to remember if it does it after a brake press/slow down gear change or not linked to braking.... Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849527 12th Aug 2020 2:04pm
A quirk of the TDCi is that there is an input from the brake lights to the ECM, and it can be shown that if the brake light fuse is blown the engine behaves differently when the clutch switch circuit is energised (this is mentioned in several other threads on this forum, although I suspect that this particular side-effect is unintentional).
The only other effect of the brake light input to the ECM that I am aware of, and probably the reason it exists, is if you brake whilst driving, for example to dry the brakes off after wading, you will find that the ECM cuts the throttle input to the engine after a few seconds and nothing you do with the loud pedal has any effect. It is a pain if you do need to dry the brakes, but I imagine is done because of the drive-by-wire nature of the accelerator to allow for the event of a major throttle pot malfunction mimicking a wide-open-throttle.
Post #849539 12th Aug 2020 2:38pm
jst
Ok, cheers for info. Brake lights certainly working but will check all connectors. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849548 12th Aug 2020 3:07pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
New take off’s are only £60-80. WARNING.
This post may contain sarcasm.
Post #849559 12th Aug 2020 3:44pm
jst
Thats not too bad, will try one off 110 first see if that cures it. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849560 12th Aug 2020 3:48pm
jst
accelerator pedal swapped this eve, will see how it goes next few days. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849632 12th Aug 2020 8:30pm
jst
fitted 110 acc. assembly and so far so good. Just the alternator/charging issue to sort out now! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #850464 17th Aug 2020 10:45am
Page 2 of 2 <12
