Home > Puma (Tdci) > 2.4 Service Items
JBLancs
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
2.4 Service Items
Sorry to revisit this topic but I'm about to service my 2.4 TDCI I've all ways bought filters etc from Land Rover which again is what I've done this time. When it comes to oils for Engine Transfer box Gearbox and Axles I have normally just used Comma which is what the local motor factors keeps in stock. Just wondering what other people are using I was wondering about ordering online from Morris this time?
http://www.whatoildoineed.com/
Not sure as it suggests normal EP 80-90 for the transfer box I am used to a thinner SX 75-90 from the comma range?
Should I just stick to the comma or does anyone have a better solution.
Ps I want to buy in bulk as I have two vehicles to service and want to swap out all oils.
Post #849145 10th Aug 2020 5:59pm
PCM
I just spoke to the super helpful people at Opie oils for most of it. They recommended a few engine ones in different price ranges, all of which are compatible, but suggested motul gear 300 for all the axles bits.
Bought genuine everything from lr parts as a service kit. Well worth it.
Post #849154 10th Aug 2020 6:31pm
JBLancs
Ahh that's good to know did you do the gearbox and transfer box?
Thanks
Post #849156 10th Aug 2020 6:39pm
Ianh
All the options on gearbox ,transfer box and diffs are well covered here. Also how to go about changing them https://www.defender2.net/forum/topic8707.html
I used
Fuchs 'Titan' for the Transfer box (2.4litres)
Castrol 'Syntrans' for the Gearbox (2.2Litres)
Castrol Axle 'EPX' for the Diffs (1.6Litres per Diff)
See page 2 on link, superspoons post.
All from opie
Re engine.
Mine is a 2.2 with dpf and I always use Millers Oils XF Longlife C1 5W30 - High Performance Synthetic Low SAPS Engine Oil. But not from opie as is cheaper from others.
Ps. Opie have a discount code on here, and do special discounts every now and then.
Filters I use gen landrover and get a discount from my local dealer so not a bad price.
Post #849159 10th Aug 2020 6:50pm
bear100
For the gearbox, transfer box and axles I use Motul 300 gear oil as recommended by Opie oils.
It’s made a noticeable difference to the gear changes not much but certainly smoother plus I only need to carry 2 oils on overlands. It’s a bit pricey but has lots of features.
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #849162 10th Aug 2020 7:03pm
PCM
Yes. As above. Engine oil (mine is a 2.2 dpf) and an everything else oil. Motul 300. Thumbs Up
Cost a tenner more but it's made a massive difference. I bought a job lot for a discount and always have a few liters in the garage for a top up.
Post #849204 10th Aug 2020 9:16pm
JBLancs
Thanks guys for your input. Looks like I need to take a look at Motul 300
Post #849227 11th Aug 2020 5:33am
