![]() | Home > General & Technical (L663) > Powerful UK ~ Riveting a new Defender |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
He managed to break part of the silver bit on his front bumper trying to take it off. TBH is don’t understand why they are removing some of the bits that they are taking off. What are they developing that might require removal of the few tire front of the car?
Rivets? He’s talking about a template to help locate where to drill the holes for them them, I would be tempted to just paint white fake rivets on........ way less hassle ![]() 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 ![]() ![]() ![]() |
Double post. Rgds.
Chris Last edited by Pacha on 7th Aug 2020 9:09pm. Edited 1 time in total |
Bit of 'trolling' going on there methinks.
Clearly they are looking at what they can produce and sell and it will involve a bit of dismantling and investigation. The 'Gerry' poster on the side window is a subtle one..... Rgds. Chris |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
Stopped watching when they tried maximum range with an empty tank on a different clip. This is the reason JLR doesn't sell manual diff locks and gearboxes anymore, knowing some people have little technical & financial sympathy. Their dealer must be on anti depressants 24/7.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
^^^ their local dealers (also mine) are pompus arses. typical new main deler with all bland RR/disco/ewoks filling the showrooms.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17600 ![]() ![]() ![]() |
I imagine that once he'd broken the panels on both sides, rivets were an ironic way of making them usable again. He already has a replacement panel for the nearside and said that the panels aren't expensive.
I imagine also that some parts are coming off just to find out how they are assembled and if they can be dismantled. Those rear panels, which apparently cannot be removed without them breaking, are a depressing reminder of how far away from its roots this new vehicle is, with throw-away parts rather than maintainable parts. |
And with that approach, people (most the time) get the service they deserve. I knew dealers they would tell tyre kickers and other time wasters in their face to buy a Toyota instead. m |
Premium, durability aren't the two words that spring to mind when looking at how some of the exterior panels are fixed. The engineering would appear to have more in common with Fisher Price than what's gone before.
Having said that, the hot plastic glue/weld contact areas on those quarter panels looked far too small for the job they should have been doing. |
LRSpain004 Member Since: 30 Jun 2020 Location: Elche Posts: 68 ![]() ![]() |
What a Joke that LR still can't build a new vehicle in 2020 where the panels line up uniformly. Can you Imagine a Toyota owner having the same issue? Let's hope the new MD knows how to get to the bottom of JLR's awful systemic quality issues.
He’s from Renault......... not that well known for quality engineering Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1330 ![]() ![]() ![]() |
Looks like it could be an expensive job to change a bulb then if you follow JLR's instructions.
The upper trim piece is likely going to snap as it did on theirs (£38.90 to replace) and/or the surrounding bodywork is going to get damaged as you try to lever off the trim (unless you are very careful). Strange that JLR tell you to remove the upper panel if the lighting panel can be removed without messing with the upper panel. Does anyone know if the lighting unit has conventional bulbs or are they all LEDs that may not be replaceable individually? |
I am trying to be optimistic. Lord knows the German leadership couldn't get a handle on it. |
They are all LEDs IIRC from the video one of those units they broke costs £36 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
