![]() | Home > Technical > Help Finding Connector Clip & Boost Leak Question |
DerekV Member Since: 12 Oct 2015 Location: Surrey Posts: 39 ![]() ![]() ![]() |
*Bump!*
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8182 ![]() ![]() ![]() |
Intake manifold removed? Exhaust manifold maybe if they took it out the top and wanted more room?
Is hissing worse cold or hot? Sounds like exhaust gas escaping from manifold to block or more likely turbo to manifold. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1452 ![]() ![]() ![]() |
This is your missing clip. Sorry I don't know the part number.
Thanks for the replies!
Jst - sorry, I forgot to mention that they also replaced the glow plugs at the same time (3 had failed, also, I imagine, likely due to the excessive idling and the "afterglow" function), which is why the intake manifold came off. I'll alter my original post to reflect this. I haven't checked the exhaust manifold as I thought this would be a less steady hissing, but I'll investigate this. The hissing is no different whether hot or cold. As I say though, it does hiss for about one second after turn the key off, and then suddenly stops when it sounds like an actuator resets - don't know what this actuator would be though - EGR, throttle, turbo vanes, etc??? DSC-off - Thanks very much for the photo, that'll help me find it. ![]() |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 506 ![]() ![]() ![]() |
The clip is (was) made by TRW Engineered Fasteners & Components.
Part number = Y034933810 ![]() Click image to enlarge . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Ah that's great, thanks!
Good luck finding a supplier
![]() The image in my post is cropped from an old TRW pdf catalogue that I have. Since then, ZF bought TRW in 2015, and then sold the Automotive Fastener business to ITW (Illinois Tool Works) in 2016. ITW's website is useless, being just an overview of the business segments they're in, with lots of old blah, blah, blah, about how much they're worth ![]() https://www.itw.com/business-segments/automotive-oem/ When the business was TRW, they were headquartered in Germany, with a UK site in Aylesbury - T R W Fastening Systems (a division of T R W Automotive Systems Ltd) Buckingham Road Aylesbury Bucks HP19 9QA Tel: 01296 717000 I've no idea if they're still there ![]() EDIT: A bit more digging (with no help from their corporate website), it would seem that they're no longer in Aylesbury. I found their new website - https://www.itw-fasteners.com/en/ Their UK location is now in Basingstoke - ITW Delfast 12 Bilton Road Basingstoke RG24 8NJ Tel: +44 (0) 1256 317686 ![]() . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Hi Paul,
Apologies for the delay in replying! Thanks for doing all that research for me! They do indeed seem to be very hard to get hold of. I'll do a bit of ringing around and see how I get on. If I have any luck I'll post back here with details in case someone else needs one! Thanks. ![]() Derek. |
