Home > Technical > Puma remapped |
For gentelman drivers that have (like me) the Puma re-mapped:
Mine don't smoke except when, expecially over the 2000 rpm, under this condition: 0. I drive up to VI gear 1. I release the throttle 2. Push very soft the throttle up to the engine is just pulling (just a very litte bit) NOW I SEE BLACK SMOKE!!! not so much but I see it. ONLY DURING THIS TRANSIENT 3. Now if I push the throttle for have acceleration (eg WOT 100%) the engine pull hard without smoke...... Could we check???? |
15th Mar 2009 9:09pm |
Nobody can check????
For people with "standard" map : can you check it (over 2000 rpm please)??? |
16th Mar 2009 1:05pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
No smoke in std set up 2.4 90 XS
16th Mar 2009 1:23pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
No smoke with standard setup in any conditions
Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
16th Mar 2009 1:38pm |
Bha!
I'll investigate...... Thank at all |
16th Mar 2009 1:50pm |
Found the problem!!!!
we must reduce the "transient map" (it work only when the throttle is moved up) more or less -5% tomorrow mornig we'll do the job!!!! later my response. |
16th Mar 2009 5:57pm |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
Hi dgardel
I have a re-mapped puma and no smoke at all. 130 crew cab 98 V8 Disco |
18th Mar 2009 5:34am |
