![]() | Home > Puma (Tdci) > Carpeting a double cab |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
I know it won't help, but my hint would be: None. I never saw a Double Cab not taking water from somewhere and everybody I knew who did carpets had to pull them after a while, because they always get wet and stinky. Never forget: cars have owner, Landrover have field service personnel.
Ops8 Member Since: 03 Feb 2021 Location: Milton Keynes Posts: 5 ![]() ![]() ![]() |
Did you ever carpet your double cab .?
Smyles_ Member Since: 26 Aug 2018 Location: Copenhagen Posts: 519 ![]() ![]() |
My 110 DC was horrible for leaking, particularly when I didn't have my canopy on - water would dribble through the tub/cab bulkhead every time I didn't park pointing uphill... Stuart ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
Have you got any sound proofing / anything under the 2nd row seat or back wall ?
While I’m here, how bad is your rear window rattle Thanks |
I had the factory carpeting which didn't go all the way to the bulkhead - it just went an inch or two beyond the the top lip of the rear seat box if that makes sense.
And yes, rear window rattle is very common. I just stuffed some thin bits of cardboard from a tissue box in the runners. I was student, so buying new felt was not an option!! Alcohol comes 1st ![]() ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
It’s taken me a few months but I’ve done most of major leaks in the double cab, a lot of silkaflex marine sealant and captain tolleys creeping crack cure. The worst bit was the tiny joint before the front gutter and the roof.
It’s still not dry, it’s a Defender... there’s no chance I’d ever put fixed carpet in it. |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
For those ‘in the know’ why is the DC particularly bad? I’ve definitely got water ingress, but it’s the passenger footwell, which is common across all models. Beyond that, nothing. Or it’s hiding, very, very well. But nothing from the tub etc and we do get a fair amount of rain here. Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 ![]() ![]() |
My carpets are fine 2007 DC
I’m sure it’s just by accident lol |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2206 ![]() ![]() ![]() |
Front of my DC is always dry.
The rear floor is sodden all the time. So added carpet to the rear seatbox, then rubber floor matt. Looks good, not wet. |
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 ![]() ![]() ![]() |
I used to get a bit of water in the drivers footwell. Used some sikaflex on the window hinge and front of the gutter and it has been completely dry - front and rear - for the last 8 years or so. I still have the original carpets (with rubber mats) and all are fine. I lifted all the carpets a couple of years ago to fit sound proofing and there was no sign of water.
Any carpet options for a DC under the 2nd row / up the back of the cab .?
No. DIY.
