![]() | Home > General & Technical (L663) > Pillar trim replacement |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3458 ![]() ![]() |
My D5 had to get A pillar trim replaced, even though it was fine on my one LR still wanted it replaced.
Something on topix “L663 tapping wind noise from A pillar area” |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Ahhhh, thanks J. There will be a few people looking forward to that then as several people have complained about a rattle near the windscreen Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
There’s also something about windscreen mouldings tapping noise.
This is what’s showing on topix ![]() Click image to enlarge |
merrion13 Member Since: 16 Jun 2020 Location: Denver Posts: 17 ![]() ![]() |
Wonder if it could be the B Pillar. Per the other "Defender Rattles" post that seems to be an area of some noises. I talked to my service advisor today and brought up that noise, and he said they didn't show any evidence of that problem yet, unlike the TSB on the windshield tapping already noted.
Stephen Park Member Since: 06 May 2020 Location: Ayrshire Posts: 6 ![]() ![]() ![]() |
Apparently A pillar plastic exterior trim is on back order, so possibly an issue. Worth inspecting closely after replacement as it requires careful masking between the black band at the top and the bottom before the centre section is colour coded.
Just had a phone call to say my car is ready for collection but the pillar trims haven’t been done as they are on back order - I kind of expected that thanks to Stephen’s post! Also they cannot find anything wrong with the tracker system that would be triggering false tampering reports........ Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
KBKLR Member Since: 16 Jul 2020 Location: Aberdeenshire Posts: 15 ![]() ![]() |
Tim, did your trims get sorted. I am hoping to pick mine up today - do you know if new trims were fitted or were the original trims refitted?
No I had complete replacements - there was a TSB covering certain VINs and any car built since mid July should not have the issue as a new design of trim/securing was fitted. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Many thanks Tim
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1051 ![]() ![]() ![]() |
Well done to Land Rover to admitting there's a fault and then doing something about it.
We had an Mercedes A Class. Dreadful tapping and vibrations from the drivers B Pillar. Mercedes went from adding a bit of grease to denial to 'Madam, you may need to accept it as a feature of the car'. |
They still haven’t admitted to the issue of the rubber seals on the door window corners tapping on the door frame (B pillar rattle) - easily fixed with a dab of Silicone glue on the rubber although I found when I went round my doors that the near side rear door already had a double sided sticky pad between the flappy bit of seal and the door frame but it had dried out and come unstuck.......... the dab of sealant has cured or prevented it on all my door frames and when I pointed this out to my local dealer they now check for the same thing before they even deliver a new car! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() ![]() Click image to enlarge ![]() Click image to enlarge |
