![]() | Home > Td5 > Rear door lock - 2003 TD5 90 |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1126 ![]() ![]() |
How do I change the lock barrel in my 90?
I have done both front doors and fitted a new steering ignition lock, because the old locks were seized and the ignition lock was temperamental. I’d really like to fit a new matching barrel to the rear door. Many posts refer to a brass pin to push in on the outside of the casing, and pull it out with the key. I have cleaned all the crud off and cannot see a pin to push in. It looks like the lock assembly is fixed together with rivets, do I need to drill these out? Puzzled at the moment! ![]() Click image to enlarge ![]() Click image to enlarge 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
Ok that’s great, thanks very much. I must have the later type. It’s all back together now, but will whip the door card off again tomorrow. 2021 Defender 110 X-Dynamic HSE D300 MHEV
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
Pretty sure your hole to release the cylinder is corroded over. Have a closer look and drill it out if needed.
![]() 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
tuko Member Since: 06 May 2011 Location: Nybro, Sweden Posts: 6 ![]() ![]() |
Would never have thought or seen that, now I can leave the drill on the shelf. ![]() Thanks. 300Tdi power Series 3 88" Ex-MOD 1992 110 Heli Support Unit |
