Home > Puma (Tdci) > 2.2 engine died |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3421 |
I have checked fuse4 under right side seat, but is ok.
Have locked and unlocked the doors multiple times, but also no luck. Immobilizer indicator seems fine, 1 flash every second or so, always on with a door open. Now I occasionally get no response when I turn the key to the ‘start, III’ position. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
21st Jul 2020 5:35pm |
It was actually less than a mile test drive before the engine hesitation, and then dying.
Thinking about it... 1. Drove a bit less than a mile, and engine shut off. 2. On first attempt, it started at once, but only drove about 100 yards before shutting off again. 3. On all consecutive attempts to start the engine, it felt like engine wanted to fire, but then dies after a second. 4. Last attempts, the engine turns over, but no sign that it wants to fire. Could it be a fuel issue? Let it stand for 1 month caused anything to block? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
21st Jul 2020 7:16pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 299 |
Check your earth bonding strap isn’t loose.
21st Jul 2020 8:51pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1785 |
I don't believe in coincidencies but.....
Ignition switch failed Loose battery terminal engine loom been stretched, trapped around infamous red lifting lug - multi plug loose? Good luck Keith |
21st Jul 2020 8:52pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 497 |
You put it aside one month ago ...
Anyhow, this is a managed engine and therefore the fault codes ( if any ) would be most interesting Don't you think ? |
21st Jul 2020 8:55pm |
Thank you for the replies so far.
There are 2 earth bondings on the transfer case. Large one is connected to the stud on the left side. That one I applied loctite on the threads that go in the adapter housing. But the nuts should make good contact with the transfer case, and transfer case should make good contact with gearbox as I cleaned all sealant that was applied before. The small cabled that bond on the right, they went in the way they came out. I did power wash the transfer case before fitting it in, but I did not check the cleanliness of the cable eyelets. Worth checking with a meter. Yesterday I checked them physically and they were ok. I will check for resistance with a meter. I will check the ignition switch. I had once an ignition failure on my 1988 90, was darn easy to point to it, not so clear on a tdci. Battery terminal looks ok. Also after quite some starting (cranking) the terminals were still cool to the touch. @ ickle, not sure what you mean by "infamous red lifting lug". Ther is a large multiplug just over the transfer case. When I was working on the transfer case, I tied the harness high to the seatbox to prevent damage. After re assembly, I fitted the bracket that should be on the left side of the transfer case mounting bolt (was fitted on the right), as the right bracket supporting the DPF temperature sensor connectors was missing. I fabricated a bracket myself to support the dpf connectors. I hope none of the wires where holding on the last copper strand, as this Defender has a history of adapter shaft failures. Indeed, this is a managed engine. I am planning to purchase a Nanocom Evolution, see if I have any codes. Unfortunately, my Forscan does not read the 2.2 engine. I hate taking the Defender to any garage. I am a DIY guy, and trust my work a bit more than someone who is pressed on time to make more money. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
22nd Jul 2020 4:56am |
If you only need to read a few fault codes, you will be happy with an OBD2 reader for some bucks.
Some DIY solutions disussed in this forum may quickly help you out. The Nanocom is costly - but it can program the ECU and the AS10... I bought one, too. |
22nd Jul 2020 5:14am |
Yes, I am also hoping to read with one of the cheaper units that connect to phone. I will keep you posted. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
22nd Jul 2020 6:31am |
at the back of the cylinder head there is a red engine lifting lug, the wiring loom routes around and in some cases against it & its caused members problems with the loom chafing through - if yours were touching IIRC you have to drop the back of the engine down on an angle to remove the transfer & gearboxes - could the loom have been damaged at this point, especially if there was existing damage there?
HTH Keith |
22nd Jul 2020 7:48am |
OMG.. that does not sound nice.
When i removed the transfer case, i lifted the transfer case maybe 2 inches, just enough to get the mountings off. I then supported the main gearbox by wedging a piece of wood between the gearbox and its cross member. I have not removed the gearbox, but I know that the clutch was replaced not long before I purchased the Defender. I hope it is not the case. I will check if I see anything with an endoscope before taking the gearbox out. Not really looking forward to do that. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
22nd Jul 2020 9:06am |
Have done some actions and checks with tge following results:
1. Disconnected earths on transfer case, clean any oils, clean with wire brush and re connect. Engine still wont start. 2. Drained some fuel from the filter drain. Did this while in tank pump was running. Did not see any water. Disconnected fuel hose supply to HP pump as do not have Schrader valve fitting. Lots of fuel flow when pump is running. But engine still does not start. 3. Checked harness behind engine as good as i could, both from above and from below. No chafing found. Just found part of the harness that looks like should have been clipped on a bracket on the starter motor loose. But no damage on harness. Wiggled and checked all connectors that I could see. Re check connectors above transfer case. Everything looked ok. Engine still wont start. 4. Dismantle covers around steering column. Noticed antenna around key barrel a bit pushed in. Pulled it out closer to key. Read the DTCs. What I found was scary. Click image to enlarge Click image to enlarge Reset all error codes... and voila engine started first time. Went for a test drive, re check for DTCs, but none found. Have switched engine off and on a few times, no apparent issues anymore. But scary, and not trusting it so much. I hope I can build confidence again. Thank you to those who contributed in some way or another. For sure you were great moral support. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
22nd Jul 2020 4:13pm |
I read that to disconnect battery on a tdci, you need to switch the ignition to On, then off, then you have 17 seconds to disconnect the battery (negative terminal).
Is it ok to keep the battery disconnected for a long period of time (weeks)? Or that can mess up ecu? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
23rd Jul 2020 6:59am |
Yes, that's the process for disarming the battery back-up alarm, if fitted, although I think it might be 20 seconds. The usual trick is to loosen the earth terminal, turn on, turn off and then yank the cable off.
Once disconnected, it'd be fine to leave it like that indefinitely. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
23rd Jul 2020 7:20am |
The disarming battery alarm - never heard about this
I have always done it the usual way. And mine behaves like any old-fashioned car. No alarm. @Dinnu : Cool, your engine runs ... keep an eye on it |
23rd Jul 2020 7:59pm |
