![]() | Home > Maintenance & Modifications > Tips for replacing rear arb? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
No jacking required
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17691 ![]() ![]() ![]() |
No jacking required. Unbolt old one, bolt on new one. 20 minute job.
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Tonser Member Since: 08 May 2020 Location: Surrey Posts: 77 ![]() ![]() |
This is on my job list too. Is the front arb equally straight forward ?
Tony |
Yes, just make sure that you align the drop links correctly.
Thanks Blackwolf
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
I remember vividly the 20 minute Lof master cylinder change that ended up taking me 2 days!! |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
When I swapped the one on my 110 the lad from Alive said to make sure the vehicle was as level as possible front to rear and side to side. It took me 30 minutes being elderly. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
Have you bought the Alive Eibach one Co1? If so, you won't believe how much difference it makes to the cornering on tarmac (and I mean that in a good way - it's brilliant).
I have indeed Joe! Looking forward to it. The fox/alive set up I have now is superb in a straight line but a big roly in the corners so if it’s as good as alive says it is, it should make quite a difference.
90 bloody minutes!! One of the bush bolts snapped. Drilled it out as best I could then snapped a tap in it! Can’t now drill it central
![]() Have a rotor broach at work so will have to borrow that. Arse. |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Guessing it's one of the bush bracket bolts under the fuel tank that's snapped? Depending on which one it is, you might be able to get to the captive nut with a cold chisel and smash the spot-welded captive nut off the inside face of the chassis member. I had exactly the same thing with mine. A few minutes with a cold chisel and lump hammer and it came off. Then just replaced with a washer and nyloc instead. Might be another option? 2005 Td5 | 90 Station Wagon | Tonga Green
It is indeed. Good call, I’ll give that a try.
I owe you a beer green machine!! Worked a treat. Couldn’t get at it with a chisel as it’s the rear most one, so did it with a punch from beneath instead. Took about 3 light whacks. Land Rover engineering at its best!!
