Home > Maintenance & Modifications > Tips for replacing rear arb?
Co1
Swapping it out this weekend, can I just crawl under it and crack on or do I need it up on stands and the axle hung low?
Post #844238 17th Jul 2020 1:16pm
ibexman
No jacking required Whistle
Post #844251 17th Jul 2020 1:56pm
No jacking required. Unbolt old one, bolt on new one. 20 minute job.
Post #844253 17th Jul 2020 2:05pm
Rolling with laughter My experience of 20 minute Land Rover jobs is that it's best to allow a couple of hours. Darren
Post #844258 17th Jul 2020 2:33pm
Tonser
This is on my job list too. Is the front arb equally straight forward ?
Tony
Post #844260 17th Jul 2020 2:43pm
Yes, just make sure that you align the drop links correctly.
Post #844261 17th Jul 2020 2:50pm
Tonser
Thanks Blackwolf Thumbs Up
Post #844263 17th Jul 2020 3:12pm
Co1
I remember vividly the 20 minute Lof master cylinder change that ended up taking me 2 days!!
Post #844276 17th Jul 2020 4:57pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
When I swapped the one on my 110 the lad from Alive said to make sure the vehicle was as level as possible front to rear and side to side. It took me 30 minutes being elderly. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #844325 17th Jul 2020 7:53pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Have you bought the Alive Eibach one Co1? If so, you won't believe how much difference it makes to the cornering on tarmac (and I mean that in a good way - it's brilliant).
Post #844462 18th Jul 2020 6:17am
Co1
I have indeed Joe! Looking forward to it. The fox/alive set up I have now is superb in a straight line but a big roly in the corners so if it’s as good as alive says it is, it should make quite a difference.
Post #844473 18th Jul 2020 7:40am
Co1
90 bloody minutes!! One of the bush bolts snapped. Drilled it out as best I could then snapped a tap in it! Can’t now drill it central Censored
Have a rotor broach at work so will have to borrow that. Arse.
Post #844558 18th Jul 2020 5:25pm
Green Machine
Guessing it's one of the bush bracket bolts under the fuel tank that's snapped? Depending on which one it is, you might be able to get to the captive nut with a cold chisel and smash the spot-welded captive nut off the inside face of the chassis member. I had exactly the same thing with mine. A few minutes with a cold chisel and lump hammer and it came off. Then just replaced with a washer and nyloc instead. Might be another option? 2005 Td5 | 90 Station Wagon | Tonga Green
Post #844564 18th Jul 2020 5:58pm
Co1
It is indeed. Good call, I’ll give that a try.
Post #844566 18th Jul 2020 6:13pm
Co1
I owe you a beer green machine!! Worked a treat. Couldn’t get at it with a chisel as it’s the rear most one, so did it with a punch from beneath instead. Took about 3 light whacks. Land Rover engineering at its best!!
Post #844574 18th Jul 2020 6:50pm
