Home > Td5 > New GearBox Fitted and Transfer Box leak fixed
London 52
United Kingdom 2005 Defender 90 Td5 CSW Belize Green
Just collected my 90 Td5 Pickup from the garage, Transfer Box leak fixed and new (exchange gearbox) fitted from Ashcroft with up graded 5th gear ratio to 0.732 and heavy-duty rear support bearings fitted. Old Gearbox all packed up ready to be collected tomorrow
Sadly it looks like I might be selling the Pickup Big Cry
Don
Post #844082 16th Jul 2020 1:24pm
roel
I like the looks:
 Roel
2003 90 Td5 (2009-now)
Post #844084 16th Jul 2020 2:12pm
London 52
Thumbs Up Thumbs Up
Post #844085 16th Jul 2020 2:13pm
familymad
My cousin on the look out for a TD5 pickup so PM if it’s going to sell
Thanks 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #844110 16th Jul 2020 5:15pm
London 52
Hi,
Thanks for the message.
If I do sell I will let you know and give your cousin second dibs as a forum member has already put his name down if I sell so he has first dibs.
Don
Post #844114 16th Jul 2020 5:34pm
lightning
My 110 could do with a new gearbox.
Can you tell me.
How much was the Ashcroft gearbox and how does it perform? And what about the higher fifth gear, is that worthwhile?
Thank you.
Post #844285 17th Jul 2020 4:25pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
If it helps, I fitted a recon Aschroft box 2 years (35k) ago and have no complaints, their customer service and advise was great. They were chosen over anyone else because they had a gearbox on the shelf and could ship it to me in 48 hours which was handy as the original collapsed on a motorway in Ireland mid-way through a trip.
I opted for the uprated carrier bearings and the v8 5th gear and would recommend the latter especially. Don't expect it to make a huge difference but it makes it a little more pleasant on motorways etc and drops the revs a touch, especially in conjunction with slightly larger tyres. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #844291 17th Jul 2020 4:47pm
London 52
Hi Lightning,
With the upgraded bearings and the upgraded 5th gear ration plus VAT, delivery and collection £1084 you also have to pay a £350 refundable deposit which you get back when you return your old Gearbox so initial total outlay was £1434. I had a garage fit the new Gearbox and fix a leak with the Transfer Box so my total was the best part of £2000 Big Cry
As Harry.O mentions with the upgraded. 5th gear ratio the Gearbox sounds and feels a lot smoother, I'm on a 2 hr drive tomorrow to Bromsgrove from Lincoln so will be interesting to see how my pickup handles a longer motorway trip Thumbs Up
Post #844304 17th Jul 2020 5:44pm
London 52
Just got back from the return journey to Bromsgrove,looks like oil leaking from somewhere (Gearbox or Transfer Box, sprayed everywhere) so back in to the garage on Monday (at their expense). Big Cry Big Cry
Post #844538 18th Jul 2020 12:51pm
lightning
That’s bad news, hopefully you didn’t lose too much oil from either unit.
Keep us informed as to what happens.
Post #844694 19th Jul 2020 9:34am
London 52
Had a good look this morning, small amount of oil on driveway looks like the oil is coming from somewhere around the transfer box housing. Spoke to garage yesterday so going back in tomorrow (Monday at their expense) to sort it out.
Just a pain as the Transfer Box has all ready been out once when the old Gearbox was removed to fix the previous leak. Was hoping with the new Gearbox Box fitted and the Transfer Box overhauled I might be leak free Rolling with laughter
Post #844709 19th Jul 2020 11:18am
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
This happened to me. The only thing they could think was that they must have damaged the seal on the main shaft when putting the transfer box back on. It took them two more attempts to put it right, although couldn’t see any damage to the seal when they replaced it. They decided to use a genuine seal instead of after market when they did it the second time. It still leaked. On the third attempt they sorted it and it has been dry as a bone under there ever since. That was two years ago exactly and 20000 miles. 2002 110 td5
Post #844900 20th Jul 2020 5:41pm
London 52
Hi Jim,
Back in the garage this morning, to be honest they feel as bad as I do so hopefully they can find and sort the problem.
As you mentioned I had a feeling that it might be the case that the seal has been damaged during fitting, watch this space Thumbs Up Thumbs Up
Post #844903 20th Jul 2020 5:50pm
miker
I would look at the intermediate shaft in the tbox casing. It wears and ovals the bore it sits in, and the only real solution is a new casing, or sleeving a worn casing. The shaft can be seen on the front side on the tbox, right up beside the gearbox.
Post #844922 20th Jul 2020 7:22pm
roel
I was thinking about that too.
But it is not always that bad that the hole isn't round anymore. The O-ring can be damaged. Roel
Post #844985 21st Jul 2020 7:19am
